Kind of Blue
MrBonus's Avatar
Easier steering after Turbo Tie Rod install and alignment?
I finally had the Turbo tie rods installed and wondering why I didn't do it sooner. The steering is much more direct and it now takes about half of the previous steering effort.
My car always felt like it took some serious muscling to turn, I assumed it was part of the no power steering experience, but now it only feels a hair harder to turn than a normal power-assisted rack.
Does this mean my OEM tie rods were shot?
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 12-04-2014, 05:42 AM
Seems more likely to be a result of the alignment - I know getting the front end toe and caster right makes a huge difference in steering effort.
I've interchanged both the turbo, non-turbo, and even direct heim joints and haven't felt much difference in steering effort.
Chuck.H
'89 TurboLookTarga, 386k miles
Old 12-04-2014, 06:24 AM
Kind of Blue
MrBonus's Avatar
Chuck.H
Makes sense.
I have no frame of reference since I haven't driven another 911 in a while and I don't know what the alignment was prior to putting the tie rods on.
Old 12-04-2014, 06:48 AM
Taking it apart is easy
Jerome74911S's Avatar
Ditto on this. No change in steering effort when installing turbo tie rods on my car, but then the toe and caster were fine before and after.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 12-04-2014, 07:15 AM
83 Targa
MrBonus... I just did my Turbo tie rods and noted much better twitchy responsiveness. I also added the bump steer kit and that made a big difference in feel over bumps. Did Bear Alignment do your alignment? They did a nice job on mine and were reasonably priced.
Old 12-04-2014, 02:57 PM
Kind of Blue
MrBonus's Avatar
No, I went to Brian and Jim's. Both came highly recommended, just flipped a coin on the two and was very happy with their work. The alignment came out to a whopping $69.
I believe they lowered the front about a quarter inch in the process and it looks much better and it drives so damn well that I'm kicking myself for not doing this two years sooner.
Old 12-09-2014, 04:55 AM
Yes that is Pasha cloth
redstack's Avatar
I've been wondering about the alignment of my car, it's so heavy that I am worn out by the end of an autocross run.
84 RoW, slicktop coupe, with Pascha baby!
08 GTS Cayenne
Old 01-10-2015, 06:09 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 Proper Caster will make a significant difference.
'85 Carrera Targa
PCA/POC
Old 01-10-2015, 10:36 PM
Not to thread jack but man you've got a gorgeous car.
~Andy
1983 Porsche 911SC Blk/Blk
1956 Ford F1 - Patina
2013 Toyota Tundra 4x4 5.7
2013 Honda Pilot
Old 01-10-2015, 11:46 PM
