Member 911 Anonymous
Hey Karl,
Not for nutin, but consider getting a battery tender with a maintenance cycle like a C-Tek 3300. Your New Battery will last longer and it will insure you have 12.6+ volts prior to start up. The maintenance cycle is important so it can de-sulfate the battery for you. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Glad it worked out.....BUT a decent volt meter is a must for old Porsches.
More complete info at: Battery Basics: A Layman's Guide to Batte | BatteryStuff Articles
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Thanks PATZ. Got small, non-pro VM. Works fine. How's winter swell off Newport?!
