wannabee wannabee
Jwest shiftrod weld broke
Surprised me while moving to 5th accelerating on the highway. Good thing I was able to nurse it home. As pic shows th
![]() e rod weld broke. Seems all I need is to bring the unit to a good welder. Is there a type of weld preferred to avoid this from happening again? Lever is spring loaded and rests on 3/4 plane so I think theres enough stress on this rod moving when selecting ither gears aside from 3/4. Sent from my iPhone using Tapatalk
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) Last edited by WIL84911; 11-29-2014 at 12:22 PM.. |
Interesting... Mine didn't break but came off to the same effect !! I had to retighten those screws and added JBweld for good measure... I'd ask them for a new one, if it broke !
wannabee wannabee
86FlatSix
Glad you were able to make it back home. I just posted pictures on the thanksgiving thread.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
wannabee wannabee
I miss driving my car (waiting for that replacement part). Just venting folks.
Hmmm.... Maybe there is something to the high price of the wevo....
TIG weld is likely the answer to your question IF repair and not replacement is the only option, but only after speaking directly with the manufacturer which would have been the correct thing to do before "venting" here.
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
wannabee wannabee
Racer
Maybe not, but it is a thought. I was a little taken back by how little came with the wevo shifter. For less money the rennshift gave me a bit of envy, but I had gone with the wevo from trusted advice. If nothing else, it is solid with the cast shift lever. The shift lever seems to be a weak point of design in the rennshift based on the experience of the OP. That is a high torque location to have a weld.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 12-18-2014 at 07:57 PM.. |
Racer
Too funny....welds are not uncommon in high torque "locations". But a shifter is not a "high torque" application. The problem isn't that there is a weld there. The problem is that the weld was not an good weld.
Racer
Oh, I bought my Rennshift in 2011 and the part at that location is not welded. It is machined.
It would appear that JWest Engineering made a design change to fix an issue some of there customers experienced. This is standard operating procedure in this industry. |
Porsche short shift kit + Seine spring loading. You won't have these issues, and money in the bank.
Racer
I bought the Rennshift setup because it didn't use the Factory tower. The Rennshift tower is much more robust, offers much better spring loading adjustability, and offers better reverse lockout options. |
The one feature I like in the Seine versus the WEVO or Rennshift is the tabs that relieve the spring tension when in 1st and 2nd gear, much like the stock tabs do for 5th and reverse. I followed the "Blueprinting the 915 shift housing" procedure on the Seine website. The whole setup shifts like "buttah". I couldn't be more pleased!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
The shift rod with a weld was an interim replacement by my supplier because he was out of the material used for the full length shaft. Only about a half-dozen were produced this way as a stop-gap, and unfortunately it seems (now that I have seen it apart) that there was not enough bevel put on the shaft before he welded and machined it, so there was very little weld left.
Of course as soon as the OP told me about this, the shaft was replaced with a new standard one-piece shaft. |
Get the pitch forks! Lynch him!
I think this is a case of everyone is an expert on the internet. I've seen probably a half dozen factory shifters break, so this is not an uncommon problem for anyone to have. JWest fixed this ASAP for the guy. What else can you ask for? The Rennshifter is a great device and the price is completely in line for a small quantity, engineered component. Nice work Jwest. |
I have both the Seine kit and a Rennshift setup. They are both very good but I ran into a weird fitment issue with the factory/Seine when trying to mate it up to my 3.6L conversion. The Rennshift allowed more fore/aft adjustability and solved the issue. So the Seine kit goes into my racecar...
- '72 911T - '81 911SC Euro |
Will have to admit, I've never driven a car with either the WEVO or Rennshift installed. I would like to just to experience the subtle differences, although I am thoroughly pleased with my Seine.
