Easy Fix - Running Rough & WUR Connection
My '83 SC has been running rough and it was driving me nuts. Had gone through and did a tune-up and it had no effect. Realized that my connection to my WUR was broken and did not make the connection. Finally reconnected the WUR and it solved my problem. Car is running so good I had to take it out and give it an "Italian Tune-up"! The connector is broken and will not stay attached. I did a Mickey Mouse fix but then found the Eagle Day web site (eagleday.com). They have the replacement connectors.
Thought I would share an easy (and inexpensive!) fix to a problem that has been frustrating me.
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD Last edited by vesnyder; 12-27-2014 at 06:11 AM.. |
Designer King
Are these the 2 way mini connectors?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Fleabit peanut monkey
Same type that plugs into the AAR, back of air sensor, and freq valve. With the wire clip.
1981 911SC Targa |
ROW '78 911 Targa
They are called timer junior connectors and I have/use them for harness building.
I've sold a few kits to members that didn't want to pay the crazy shipping costs others charge. ![]() Basically they are fuel injection connectors. Here are 3 styles you can find. I have the original style in the middle, and the one on the right. The quick release ones on the left are available on Pelican. ![]()
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 12-28-2014 at 12:12 AM.. |
Thread Tools | |
Rate This Thread | |
