Bill Verburg's Avatar
finally adjustable Bilsteins
Adjustable Bilsteins for pre '90 911s
Bill Verburg
Old 05-09-2025, 02:08 PM
Wow…..$$$$….even compare to my Ohlins Road/Track my 996TT.
Nice edition to the aircoled market though.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-09-2025, 04:15 PM
Not vastly different in price vs the K3 V3’s w/ raised spindles. Easy $5.5k for the set too.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/
Old 05-09-2025, 05:55 PM
(man/dude)
Jonny042's Avatar
At a glance it looks like the Bils might be raised spindle (maybe 15mm?) but only single adjustable. Nice to have them as an option, very OE+ if that's your thing.
Whatever flavor you favor, add +25% for tariffs...
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 05-10-2025, 05:39 AM
There's always coil overs and a GT3 front if you want to go that route.
Old 05-10-2025, 06:54 AM
famoroso's Avatar
I'll leave these here. Allegedly, Nitron's offering is "coming soon," replete with single or double adjustability and different height, swappable, steering arms depending on which spindle height you choose...
Also, rumor has it that Eisenlohr Racing Products is in R&D for a G Body offering.
God bless America, it's an embarrassment of riches.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 05-10-2025, 04:33 PM
nice!!
I'm looking for an inverted monotube gas shock
at least 30mm raised spindles and or shorter body
adjustable height steering knuckle
digressive valve stack, high pressure blow off is a plus
adjustable valving is a plus
all the available shocks I have seen offer some of these features, none offers all of them, it's seems odd to me that for far more plebian cars these features are all available
the Bilstein b16 g series shocks seem to be right there except for spindle height and steering knuckle height which can be fixed
got links for the Nitro and Eisenlohr products?
Cary & co. seem to be working on double arm 964/993/996/997 front ends these days
They also did a double arm for G series 91 but I have no info on it
Bill Verburg
Old 05-10-2025, 06:38 PM
Jeff Alton's Avatar
If we are in that price range, we use MCS www.motioncontrolsuspension.com We talk with their team about car weight (corner weight) spring rate, desired use of car etc... and get a custom set of dampners...
We have done a couple G-body cars and countless later watercooled platforms and the products are fantastic.
Cheers
www.turn3autosport.com
Old 05-10-2025, 07:15 PM
Jeff Alton's Avatar
I am not familiar with Nitron. Though I see they have a wide selection of offerings acrsoss cars and motorcycles.
The machining could use some finer finish passes but that is clearly a far from finished part. Not sure how I feel about the bolt on nature of the spindle and toe link arm.....
cheers
Old 05-10-2025, 07:27 PM
Titanium User
cheers
Looks like a 3d printed sample - can't wait to see that finished product!
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 05-10-2025, 07:43 PM
famoroso's Avatar
I acquired my first set of V3s (plated versions) for ~$3k in 2020. I acquired my second set (also plated) in 2021 for ~$3,300. As much as I like them, especially for road tour / rally use, I cringe at the current $4k+ price tag (for the now painted versions). Ugh.
Nitron estimated price is ~$6,500.
Originally Posted by Bill Verburg View Post
nice!!
Alas, no links, but I'll inquire.
As seen at ERP's Air|Water 2025 booth...
...The upper A-arm mount is pretty slick, but I can't imagine many 993 owners will be cutting up their chassis for it. OTOH, I've driven a 993 with, among other things, ERP's RS uprights, on the road and at the track, and I'd be DELIGHTED to have that setup on a 993, if I can ever afford one. ;-)
ERP upright (a.k.a. legit suspension p0rn) slated for a 964 RS...
cheers
Yes, relatively unknown in the Porsche world, especially the air cooled hemisphere. They have had Lotus offerings for a long time, single, double, triple adjustables, etc. I had double adjustable, remote reservoir versions on my Elise track car for 14k miles and 100+ track days. They were excellent, both more comfortable (even with considerably higher rate springs) and provided more body control than the Lotus factory Bilstein Sport package suspension. I did have them rebuilt at that point, but I am totally happy with their performance / longevity, given the severity of my use case.
Yessir. That's a 3D printed item.
Note the silver fitting near the bottom of the body. That's for the double adjustable version's external canister. The single adjustable version will not require a remote reservoir.
Frank Amoroso
Old 05-11-2025, 06:13 AM
yeah, my 993 has the RS/Cup/RSR uprights, Cary's raise the spindle another ~10mm
They had a teething problem w/ the early bearing retainer plate bolts, looks like that has been rectified
right now the MCS look like the best option for a G series 911(even though mine is really an I series), I was just shocked when I ran across the PS10 Bilsteins for G series, in the 964 up world they are a very nice street option, a couple of steps down from MCS
Bill Verburg
Old 05-11-2025, 12:15 PM
Had Nitrons on my exige years ago. Great quality wouldn’t hesitate to try out their Porsche stuff
Old 05-11-2025, 02:27 PM
JackkTheMackk's Avatar
Have you guys seen what NTP in Europe sells?
https://www.ntp.it/english/motorsport/marken/porsche.html
3-way adjustable Bilstein dampers in rebound and bump (low- and high-speed)
Bilstein PSS10 front shock absorbers for the Porsche 911 adjustable in rebound and bump with 10 clicks. Complete new front strut from Porsche Original. With 40mm cartridge and Bilstein PSS10 regulation incl. coil over system and specific setting on-demand and also travel for the use what the customer needs (street-use, race, rally etc.)
Bilstein MDS shock absorbers rear – with 2-way adjustable in rebound and compression or also with the Bilstein PSS10 System.
‘70 911E
‘82 911 SC Targa
‘86 944 Turbo
‘90 OM606 Swapped SWB 300GD
IG: @JackSchroederCreative
Old 05-11-2025, 02:39 PM
Jeff Alton's Avatar
For the G-Body cars, those PSS10 would be like all other PSS10, a crude 2 way, in that they adjust compression and rebound together, but not independently. Fine for street use. But be prepared for a failure, and then a lack of support while your car is down...
Cheers
Old 05-11-2025, 07:57 PM
A little bit rough as well …..
Old 05-11-2025, 08:00 PM
Cheers
So on the MCS 2WR for classic 911
for a car that's 60+mm lower than stock
how long a shock body do you recommend?
how does MCS handle steering knuckle height adjustment, single sheer, double?
I see that they have 2 options
cartridge that uses donor spindle 2way
new spindle 2wnr
What advantage does the new version offer?
i
Bill Verburg
Old 05-12-2025, 04:47 AM
Jeff Alton's Avatar
Apples to Apples....
2WR are remote canister. Also available is a 2WNR, no remote canister. You can talk to an engineer about your car's weight and spring rate and the way you want to drive it (track, performance street, or a mixture of both, even talk tire compounds). Then get a custom valved set up vs an off the shelf product. Kinda like when Jack French was still alive and working at Bilstien NA and you could get custom help....
For your 60mm specific requirement, talk to them. Or have a dealer talk to them on your behalf.
Cheers
Old 05-12-2025, 08:29 PM
