Air Cooled
I just removed the fogs. 1974 grams = 4.35193 lbs gone! The next question is, where can I get inexpensive running light rubber to get that Euro look on my bumper? Any used ones out there?
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 Last edited by Craig_D; 01-04-2015 at 04:31 PM.. |
Air Cooled
Beautiful car DeRRis! Really clean and very sharp!
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
This UK site has them new - Bumper Rubber Trim - Items - Type 911
Shirish 1987 Carrera, Granite Green |
Air Cooled
Thanks for the link!
Here are some comparison before/after pics: Head on: ![]() ![]() 3/4 front: ![]() ![]() I like the cleaner look for sure. I just need to plug the holes (or cut out brake duct cooling)
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 Last edited by Craig_D; 01-04-2015 at 04:41 PM.. |
Fogs off.
1986 Porsche 911 Targa 1983 911 sc 2015 WRX |
I used my right fog hole to duct to my fender carerra cooler. As of now my left fog is still there.
AKA SportsCarFan
Doug Miller 1988 Guards Red Carrera |
Banned
To prove it to yourself, on a dark night park on the side of the road and run your headlamps. Then turn on your foglamps and see if you can see anything any further down the road. The big test is when you cover your headlamps with cardboard to show yourself what the actual beam pattern looks like. Even worse, some folks try and re-aim their foglamps to act more like headlamps, which also does nothing for distance. It just throws more light to the sides and up, right into the faces of drivers in the other direction. |
Air Cooled
I'm not sure if you're aware of this, but the voltage for the headlights (without the relay) runs all the way up to your steering wheel stalk, and then to the headlights.
When I installed the relay (before the Euro H4s) there was a significant bump in light output. Another bump in light output with the H4s. They're quite bright. It also solves the stalk issue of lights cutting out. My high beams cut out on me before I installed the relays in '09 and they've never cut out since. Also, there is a wire/plug upgrade that you can do for the Euro H4s that will help them handle the high output bulbs. It's in my sugar scoop to H4 conversion thread. I'll dig up the link.
I picked up SC valance from a fellow pelican and will also be going fog gone.
2010 Carrera S GONE 2022 Cayman T 2007 GT3 1988 Carrera |
Formerly known as Syzygy
A big +1 on this. The factory setup has no relay on the headlights. The voltage/current drain from all the resistance of the wiring back through the dash, headlight switch and signal light stalk is significant and affects the light output of the headlights. In addition, the plastic H5 lights on your '88 were never known for their light output to a correct, useable place on the road, regardless of the bulb wattage. The best course for improving lighting on your car is a headlight relay for wiring safety and switch longevity, and a headlight backdate to sugar scoops with 7" round H4 lights or to the (more expensive) Euro H4s. Even without high output bulbs, either headlight change will make a HUGE difference in your on the road lighting. The factory fogs really aren't designed to throw the light down the road as they're a 'fog' light and spread illumination low and wide for a short distance in front of the car. Besides, yours are likely all sand blasted and pitted so are even dimmer. And just try to find new replacement lenses for the Carrera fogs...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 01-04-2015 at 05:43 PM.. |
Laws REQUIRE that main beams be used in ALL night time conditions, making the close-in fog light beam pattern USELESS! |
HIDs usually require a bunch of fabrication and cutting of the headlight bucket to fit the light assembly. Then the lens has to be changed out for one that's clear so the light from the shiny new HIDs doesn't get scattered all over the place. Sure it's doable and may possibly even give slightly better lighting than a Euro H4 solution, but I didn't get the feeling that FastCarFan was up for that kind of modification. My apologies if that's the case. And most HID retrofits seem a little out of place to my eyes. The ones in the Singers look not too bad, but they also have the chrome looking projector surrounds, kinda mimicking a factory like appearance but with a modern twist. I'm also not convinced of the superiority of HID illumination. I have yet to read anything that proves they're better than a GOOD incandescent system. Even in my own personal, and admittedly not quantitatively measured, experience, my 3 series Bimmer HIDs don't illuminate any more than the 80/100 watt H4s on my 911. Sure, the light colour (4400 K) is different and the bluish white colour temperature might give the illusion of better illunmination, but it doesn't seem to offer any. And it's colour also strains my eyes a bit more during a long night time drive, especially in the winter with all the snow. And HID bulbs in a light designed for incandescents? Uhh, no comparison. HIDs DO use a lot less electricity if that's a concern - 35 watts versus 100 watts in my cars on high beam. But that doesn't address the OP's question...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 01-04-2015 at 06:46 PM.. |
Craig, the car looks great with no fogs. Thanks for the pics
I was also considering this mod in my Carrera. However, I'd have to get a new valence so I didn't have a couple of big holes where the lights were. I do use my fogs on the highway mostly for visibility to other drivers even in good conditions. I've installed 35 watt bulbs so the plastic surrounds don't get over heated. I don't use my headlights in that situation because of the 80 watt low beams. Maybe I'm just being over cautious... I'd personally leave the wiring and just secure it behind the bumper or something. The next care taker of the car might just want the fogs. I also have rear fogs (located in the rear reflector strip and not the below the bumper light) so they'd stay as I find them useful in poor visibility conditions, especially at night. The factory tail lights aren't all that significant, and the rear fogs give just that little bit of 'don't rear end me in the fog when I'm driving slowly' kind of security.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
The new "micro" ballasts easily fit inside the headlight bucket. |
Banned
During the day, go ahead and do this, I don't think it matters much. At night, PLEASE don't. Your headlamps provide plenty enough light to be noticed from more than a mile away. The extra light thrown in the eyes of oncoming drivers really sucks.
On the other hand you may be seeing driving lights placed in the fog light position, as is the case, seemingly, with Ops car. |
Eva
No fogs. Less is more. Aside from the fact that they look like an Auto Zone bolt-on from the factory
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Another fan of no fogs. I don't think mine originally had them, but had been added on as the wiring and switch didn't look factory. I promptly removed them and never looked back.
I also don't require a front license plate, so welded up the holes in the valance for a clean look.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
