The fog lights illuminate the sides of the road, not so much down the middle. This helps in fog, when you should be going slowly anyway. |
I was testing my fronts in a store front window the other day, and realized that my fronts are woefully dim compared to my rear LEDS, so I ordered a set of 1157 LEDs from SuperBrightLEDs this past week. :) |
Craig, are the LEDs you've ordered simple bulb replacements and use the existing housings.
I took a gander at the SuperBrightLED site and it looks that way, no? |
I read your mechanical switch thread, I'm definitely copying that mod. |
http://forums.pelicanparts.com/uploa...1420575701.jpg |
Years ago in my 75 911 I mounted Cibie driving lights like these:
http://www.holden.co.uk/productimagesL/010_594.jpg Had them wired up to the hi-beams what a HUGE improvement! You could replace the Fogs with hi-beam driving lights. |
I used these for all indicator lights on my car, but I found the rear bulbs were finicky. Sometimes they would be super bright, other times, they were dim/fluttery. Every time they were dim/fluttery, I'd pull off the lens, push on the bulb, and they would be bright again. After playing with it for a while, I ended up melting solder on the bulb contact. I put so much on it that the bulb wouldn't install, and then I filed the solder way until it fit really tight. Now my bulbs are super bright every time. Not a fault with the bulbs, but more loose fitting circuit boards on the inside of the rear light assemblies. |
Good to know. Last question. Does bulb replacement require install of resistor boxes or is it simply plug and play? (thread-jack over) |
Simply plug and play.
As far as dimming connections, I've found that I've always needed to put some electrical tape on the stalks of all of the rear bulbs to keep them solidly in place. Maybe this could help. |
Here is a thread on the relay swap. http://forums.pelicanparts.com/porsche-911-technical-forum/287390-i-solved-led-indicator-problem.html |
Will a 84-89 Carrera valance fit on an SC without any mods? I like the way there fogs look so much better (recessed) than the dangle bobbers on my SC.
Sent from my iPad using Tapatalk |
Even an 87's fogs are useless. I had my valance welded shut and repainted. Body guy said it was easy. Never used them in my 6 years of ownership.
JR |
Oh ok. But other than that it bolts right up to an SC? Please excuse brevity and spelling errors. Sent using iPhone |
Fogs, or No Fogs?
Couldn't agree more. The fogs add "weight" visually to the lower front area of the car and gives the illusion that the car is sitting lower. I like the clean look of no fogs, but like you said the car appears higher off the ground and almost like its missing something to me. That's why I really like the post 83' carerra valance...fogs are there but more more low profile and they look intentional....unlike the ones on the SC. Someone already said autozone bolt ons...your right. Please excuse brevity and spelling errors. Sent using iPhone |
For the same effort, you could replace it with a fogless valance. Readily available, the new ones come with two tabs on the right side so they will bolt up to any car from 1974 through 1989. None of the fog lights do anything worthwhile, hardly anybody drives in fog anyway, and the lenses get blasted with grit and look terrible in not that many miles. Can't see why anybody wants something that is as useless as those. JR |
| All times are GMT -8. The time now is 09:37 PM. |
