1976 carrera
boxster s calipers upgrade for 76 can I do it?
Hi all,
I have a 76 911s, the car has break booster, with 19mm master cylinder,
I picked up a full set of 2001 boxster s calipers from a dismantler,
But I red some threads saying that I cant use the calipers,
please help from experience,
Can I use them?
What are the exact parts necessary for this upgrade
Gilad
Old 01-09-2015, 09:23 AM
1976 carrera
bbb
Old 01-09-2015, 11:06 AM
TheSt|G's Avatar
What's broken again?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 01-09-2015, 11:15 AM
I believe there is an adapter that will work, but if not you will have to update your struts to later with 3.5" caliper bolt spacing. That's the only real issue to make them fit. I can't tell you if there will be bias issues etc. front to rear, but If you do a search on tis forum there is tons of info.
Chris
'75 911s 3.2 - Ice Green Metallic
‘87 951, '05 987 S
'21 Jeep Gladiator
‘18 Tesla ModelX 100D, ‘20 Model 3
Old 01-09-2015, 11:16 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Probably not as much info as you may think. Especially on the Boxster S calipers.
I am talking only from a few phone calls and the install of the standard boxster front kit on my 81.
Don from EBS called me not too long after I bought the standard kit. Early 2000's. Said they had a setup for all four corners using the Boxster S calipers but you had to get the right master cylinder (adjustable?) as the front/rear bias was not right with the SC master/proportioning valve. Guessing it would be the same scenario for your 76.
If I recall, 15" wheels will not allow clearance for the standard Boxster calipers.
Call EBS Racing or search for install kits for the Boxster kits.
1981 911SC Targa
Old 01-09-2015, 12:31 PM
Northern Motorhead
wildcat077's Avatar
Gilad,
Call Dave at TRE,they sell an adaptor kit for Boxster brakes although i don't think the Boxster "S" brakes will work on your car,you would of had to get the regular Boxster calipers ...
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 01-09-2015, 01:01 PM
Bill Verburg's Avatar
I'm truly curious as to why any of you think this improvement
Bill Verburg
Old 01-09-2015, 01:13 PM
gtc gtc is offline
abides.
gtc's Avatar
Because they look cooler, Bill.
Graham
1984 Carrera Targa
Old 01-09-2015, 01:22 PM
They are red they have to be better
2006 Cayman S
93 RS America white(now living in Arizona)
1974 911S/CARRERA (now living in Australia)
Livermore Ca.
Old 01-09-2015, 01:34 PM
Enthusiasm > Expertise
reddogmotrsprts's Avatar
You will need adapters for front/rear. The fronts are $250 retail while the rears are $450. The bias will be less than optimal and you will want the 23.8mm master cylinder to fix the resultant pedal feel.
This is not an upgrade I would recommend without hesitation, as it biases braking towards the front, where you are less likely to want it, and adds more heat to rotors which are already near their limits on the track.
Red Dog Motorsports
Old 01-09-2015, 01:59 PM
1976 carrera
Thanks guys,
Rethinking this action
Gilad
Old 01-10-2015, 02:15 PM
