Engine Bay Refresh
This group was helpful in convincing me to keep my 3.2 rather than spend a bunch of money to replace it. Having said that, there is a suggestion to return the heater system to the one that came in my 69 tub. Does anyone have a picture of a 1969 911 engine bay showing the tin and other components? As noted, I have a 3.2 installed. Have attache a picture of the current condition. I am thinking the 3.2 heater, etc is really not being used.
Thank you ![]()
'86 944T black/red, chip, fuchs 8's and 9's- Sold '97 Boxster silver/red, big mistake - Sold '99 C2, silver/black, RoW M030 - sold "69 912 white w/ '86 3.2L (like the pic, just not the pic) |
Call 911
I have an SSI exhaust system installed on my '88 with the 3.2L engine. Not wanting to eliminate the engine mounted heater blower, here is what I did:
SSI Exhaust – Heater System Workaround If you are running this type of exhaust system, you may want to consider this. Heat output is amazing.
Dave Kirk My Porsche restoreth my soul. |
I deleted the electric blower on my '88 by using a fan duct from an earlier model to get the look you're after and retain the heat function using the engine fan like the '69 did originally.
Like this except I used a black hose: ![]() '87 Carrera Heater blower(s) delete question...
SWB 912 - G50 Carrera - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com Last edited by Mr. Merk; 04-03-2025 at 01:57 PM.. |
Our host has the key part: https://www.pelicanparts.com/More_Info/93010632101V2PH.htm |
thank you all for your suggestions. I will check tomorrow since there may be a switch under my dash put there by a previous owner that runs fans. Not sure why or what. In the meanwhile th link suggested above does not work.
Still here
That's why the switch is there in yours. Needs a relay as well if not already there. |
Maybe, but it is clearly an aftermarket tiny toggle.
This guy has a video with all the parts and how to do it:
https://www.youtube.com/watch?v=MXuTpWfD5vQ |
Thank you for that link. Apologies for the tardiness in my thanks, been distracted by recent events
