Question Need help to identify wire on engine loom
Having just installed my '81 SC engine after a full rebuild, I have a wire that I'm not sure where it should be secured (see attached pic). It looks like it want to grounded along with the high tension leads, but as it is brown in colour I'm not so sure (if it was black I wouldn't hestitate).
The engine starts and runs fine without it, although the oil pressure gauge is up the creek.
Any suggestions ??
Thanks, Simon
www.adelgigs.com/911sc.htm
Old 10-20-2002, 06:47 PM
That wire goes to your Coil - ground side post. 81'SC
Old 10-20-2002, 07:15 PM
Warren Hall Student
Bobboloo's Avatar
Brown is ground on Porsches. Oil pressure should be green with red surrounds if memory serves me.
Bobby
Old 10-20-2002, 07:29 PM
Thanks guys - I've attached it to the -'ve side of the coil and the car still runs - (no sparks or smoke).
Cheers, Simon
Old 10-20-2002, 10:29 PM
