jwakil's Avatar
Just rebuilt top-end, should I still have startup smoke?
I just had the top end rebuilt on my 930, by a reputable shop. It is in the breakin period, and I'm getting a little smoke on cold startups (maybe slightly less than when I took it in with lousy leak down results and broken rings). I was expecting that after a fresh rebuild, there shouldn't be hardly any startup smoke. I can understand after 20-30k miles when rings are starting to leak, but right out the gate? Is it because it is in the break-in period? I'm hoping it gets better and not worse after break-in.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 01-25-2015, 07:47 PM
I thought all 911's puff at cold start after sitting.
Old 01-25-2015, 07:59 PM
Banned but not out, yet..
RSBob's Avatar
Both of mine did. It was disappointing but it is the nature of the flat 6.
Old 01-25-2015, 08:12 PM
I would rather be driving
jpnovak's Avatar
How many miles does the new engine have? Sure its not the turbo smoking?
Old 01-25-2015, 08:23 PM
jwakil's Avatar
Well, I can say the engine has less than 300 miles since rebuild. I'm not sure how many miles are on the turbo, as it is an upgraded k27 , unknown install date. Lets say the turbo probably has 30-40k miles. Regardless, my thinking is a turbo would smoke all the time, not just at startup.
Old 01-25-2015, 08:54 PM
Senior Advisor
James Brown's Avatar
good sign that oil is getting to the cylinders, bad sign if it's leaking past the valve guides. I would drive it hard for couple hundred more miles
08 Cayenne Turbo
Old 01-25-2015, 08:58 PM
ROW '78 911 Targa
timmy2's Avatar
Give it a few good "Italian tune ups"
Old 01-25-2015, 09:36 PM
Almost Banned Once
sc_rufctr's Avatar
At... "less than 300 miles since rebuild" I wouldn't worry just yet.
After 1,200 miles let's see how it is. I bet it will be a lot better but a puff of smoke at start up is normal for a 911/930.
Just a puff though.
- Peter
Old 01-26-2015, 01:16 AM
Remember that the rings may take a few hundred miles to seat completely
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 01-26-2015, 04:27 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Those were my thoughts. Here is a link that talks about oil in turbo chargers.
On the up side many of the issues have to do with turbo related issues rather than the turbo itself.
Common Turbocharger Problems
Also, the turbo charging forum here is a good place to search or post if you boil it down to the turbo.
1981 911SC Targa
Old 01-26-2015, 09:11 AM
