proper fix for control arm mounts?
Greetings,
the holes in the control arm mounts (where the arm mounts to the body) in my 82 911 are egged out. that is, they have become bigger than they are supposed to be. that allows the control arm to move slightly in the mount which dynamically changes the allignment on the rear wheel when cornering. Can anyone tell me the proper fix for this? thanks -Bryan |
i've heard that you can assemble it with properly sized heavy washers on the outsides of the mount and tack them then disasemble and weld them in place. has anyne done this or have any other reccomendations?
Do you mean the rubber bushings or the bores the rubber bushings go into? Jim
Thread Tools | |
Rate This Thread | |
