2.7S engine in VW type2 bus exhaust concern!
Hi guys, I'm about to put a 1976 2.7 engine in a 1971 VW bus. The heat exchangers are on the engine, I believe one connected to the other one for a single inlet into exhaust. The exhaust is missing. What should I get? Do I have to stick with this configuration? Is it more simple/possible to have one header on each side connected to a dual connectors exhaust or any more simple/ cost effective way?
Any help/education appreciated indeed!
Old 02-03-2015, 02:04 PM
Vintage Owner
Jack Stands's Avatar
Either heat exchanger should work if it fits in the confines of the bus engine compartment. I think there is no 'cheap' option but if you already have the heat exchangers, I'd try to use them. As far as a muffler, the factory one is hard to beat but is not inexpensive and it may not fit.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 02-03-2015, 02:42 PM
Use the 2.7 exchangers and fab up an exhaust or have a muffler shop do it from scratch to fit your new home for the motor. That would be about the cheapest option I would think.
Old 02-03-2015, 04:14 PM
you can go at least 2 ways. trim out the bottom of the bumper to clear the stock muffler or use the late exchangers that exit left front and cut the cat off and weld on a thrush muffler down the left side. i've done both.
206 637 4071
Old 02-03-2015, 06:18 PM
gumba's Avatar
I tried a few different approaches and ended up making my own. The one muffler that would fit with the least amount of work would be a Abarth for the 2.2, or something similar.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 02-03-2015, 07:46 PM
Hi Jack Stands, I like your approach full of common sense! I can't agree more. Thank your for the advice!
ClaudeUS2
Old 02-04-2015, 08:33 AM
Hi sedsn, I will submit your advice to my cousin/ mechanic who will perform the engine swap starting on February 23rd...
Thank you!
ClaudeUS2
Old 02-04-2015, 08:35 AM
Hi John, I will most likely have more questions for you after submitting your post to my cousin/ mechanic! Thank you so much, I will go on your website and I see your phone number.
ClaudeUS2
Old 02-04-2015, 08:39 AM
Hi Harold, thank you so much for the advice and pictures. I see you did cut the rear of body with some engines. Are you able to tell me ( or another member!) if its a necessity to do the cut for a 2.7 engine? I'm guessing the exhaust alone will create this need?
Please let me know!
ClaudeUS2
Old 02-04-2015, 08:57 AM
gumba's Avatar
The top of the apron was cut to match the shape of the engine hanger. I made the muffler to clear the apron and the bumper without cutting. To fit a Abarth, or I also think a SuperSprint would work, I trimmed the bottom of the bumper, which isn't noticeable.
The amount of cutting depends on how you make the rear hanger. I used the same tin on a 2.4E motor as well as the 3.2.
Harold
Old 02-04-2015, 09:09 AM
Thanks Harold!
ClaudeUS2
Old 02-04-2015, 09:31 AM
