scott (guest)
Guest
Posts: n/a
trying to change my 1995 993 key head. got a new one w a LED light. much brighter. how do remove/install the metal key?
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-10-2015, 05:20 AM
Nick at Pelican Parts's Avatar
I'm pretty sure you split the old key open using a flathead screwdriver. Then remove the key from the plastic body and transfer it over to the new body.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
KNS KNS is offline
Once opened there is a little tab on the side which slides into the metal key blade. carefully pry this little tab up and out of its slot to release the metal portion.
Kurt
Old 02-10-2015, 07:23 AM
