E-85 and PMO carbs?
Anyone done this? I know a number of rally and other motorsport guys in my area running E-85 on all kinds of crazy boosted applications. Besides the fuel line issues, does anyone see any reason PMO carbs might not like it?
Old 02-12-2015, 01:07 PM
Straight shooter
Lapkritis's Avatar
Lots of soft metals in those precious carbs... I sure wouldn't want to experiment. E85 is popular with boosted applications where the detonation resistance and relative volume of fuel in mixture is of far greater benefit. On all-motor you won't see the same magic.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 02-12-2015, 02:05 PM
My motor ended up at 10.75:1 and I was thinking it might make a good alternative to unleaded race gas.
Old 02-12-2015, 02:49 PM
Straight shooter
Lapkritis's Avatar
What state are you in? Is the car equipped with a catalyst? Street or track? Single or twin plug?
Old 02-12-2015, 03:24 PM
Oh yessss,...lots of reasons.
E85 & carburetors are mutually exclusive. That fuel is best suited for FI.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-12-2015, 09:05 PM
The car is being built for Rally-America group 2 class competition. The motor is a 95mm SC 3.0 with oiling mods to cranks and block, Ti retainers, upgraded valve springs, DC60 cams and ARP fasteners. My initial intent was to go EFI with the motor, but after some thought I was interested in the carb / 12 plug dizzy route.
Rally america rules limit fuel to 100 octane, but do allow E85. I have a few buddies who are running E85 in high compression NA motors with good results. One thing to keep in mind is that a rally car here will run 120 stage racing miles at any given event and up to another 150 of transit from stage to stage. This adds up to a lot of race gas.
Old 02-13-2015, 02:38 AM
Straight shooter
Lapkritis's Avatar
If EFI is an option for the competition then would you reconsider? Some aftermarket efi have automatic table switching and use a flex fuel sensor. This would also allow for knock control and race options (if no catalyst) such as launch control, traction control, flat shift... Etc.
Old 02-13-2015, 04:30 AM
This is still an option as our class rules are quite lenient. That said, a cat must be part of the exhaust. I actually have a very high cell count core that was produced for WRC cars and planned to integrate that into the system eventually.
Old 02-13-2015, 04:48 AM
Straight shooter
Lapkritis's Avatar
Check out http://www.VEMS.us
Supports table switching/flex fuel sensor. Lots of advanced options and bargain price.
Old 02-13-2015, 05:27 AM
LJ851's Avatar
I don't think the carbs would play nice with a cat.
Old 02-13-2015, 08:24 AM
l_turn9's Avatar
I suggest you go to the expert - Richard at PMO will be happy to discuss it with you. Send him a note via FAX and include your phone and/or email. His fax is 310-394-6313
HTHs
LarryT
74 911
Old 02-15-2015, 09:56 AM
