Goodbye crusty old fusebox, hello Fred Cook!
So a quick search on "fusebox replacement" "ATO fusebox" or "Fred Cook" will turn up a bunch of threads on replacing the old fuse panel. So why a new thread? I thought I'd document the process a bit and show a few photos, in case this could help others considering the upgrade.
In my SC, the old fuse panel had become brittle, with wiring that had changed color from overheating in places. While doing the wiring for headlight relays, I decided to check tightness of the screw terminals, and the first one I turned broke off along with the corner of the panel. The fuse and holder flew off into my garage or frunk somewhere, never to be seen again. That was the last straw! Fellow Pelican Fred Cook makes a modern ATO fuse panel that mounts in the stock location, so after reading positive feedback from others I decided to order the panel and make the switch. Its a very, very well made part and Fred shipped to me just days after I ordered. The instructions were good as well, but be forewarned: if you have 10 thumbs and ADHD this may not be a job for you. A few notes:
The original panel in my SC. Doesn't look too bad but a couple fuse locations were fried or broken: ![]() I made masking tape labels for every wire beforehand to save time and hassle. T is top and B is bottom: ![]() Tedious labeling: ![]() The crimp tool, you need one of these, as there are many connections and they need to be solid. I bought one from Knipex, made in Germany: ![]() Crimping done: ![]() The (almost) finished job. I took this pic before adding a couple fresh wires to run from the battery plus a little tidying up, but this is basically the end result: ![]() So when all was said and done, I'm really pleased that I tackled this job. There were several "hotwired" connections in the wrong locations-- no fuse protection for any of the AC blowers for example, these were wired straight to 12V on the top side of the panel! Plus the front condenser fan motor was already melted into a blob. Fire waiting to happen. Along with correcting the scary stuff, I also added separate AC blower fuses inline, a fuse for the interior lights, the Jwest headlight relays I mentioned above, and a couple supplies of 12V from the battery (AC and headlights.) And the best part: everything works, and the car started right up. Woohoo!
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. Last edited by evan9eleven; 02-13-2015 at 09:43 AM.. |
Looks great, but quite a chore!
For those who want to save 90% time, 90% cost and 90% crimp joints/connectors, see Cheap and easy ATO fuse block installation
1982 911SC Wine Red Metallic OMG I love this car! |
El Duderino
Congrats! It's always great when you pass the "smoke test" on the first try.
![]() It is a tedious job but very rewarding in the end. I did not know it until I went to replace mine but one of the old fuse panels was cracked and several of the fuses were loose. Could very well have been contributing to some of the "ghosts" I was chasing before I did the job. I also found some things that had been wired poorly or incorrectly over the years. I might've even done a couple of them.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
That looks awesome. Its on my list to do and clean up all the old wiring from all the accessories that I've deleted.
Mat P 1988 911 Carrera |
Great job! Install looks nice and clean.
I really need to do this. I lost the shunt between two terminals that gets me switched power to the ignition box (CDI) and had to have it towed. I didn't know what was wrong at this time. I switched out the fuel pump relay and it ran fine again, only to not start after work the next day. I at least had access to a multimeter this time in the parking lot at work, and was able to get the diagnostic right. I made a jumper to get me home, then rewired the circuits going to the two broke terminals through blade fuses. It works, but obviously doesn't look clean.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
Gunga Galunga
Really nice work!
Slippery Slope Victim
Thanks for the write up. This is next on the to do list.
Mike² 1985 M491 |
Black and Blue
very clean...great job!
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
looks great, I just installed one in my car. It's a quality part and well worth the effort.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
Fantastic job! This is on my to do list if and when the car returns to me
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 02-13-2015 at 12:01 PM.. |
Yup, this is doing it right.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Racer
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Definitely on my list of upgrades. Thanks for posting.
Not so fast........
Don't be too harsh..... Algernon's method is just another path to the same place! Only time will tell, but I suspect that his installation will last for a long time also. I suppose which path you choose to take depends on your ultimate goals for your car.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Racer
Fred,
You are too nice! Algernon's method gets the car converted to modern fuses, but your solution is just so much more professional!
Nice job!
Timely thread, I am working on my Fred Cook fuse box replacement now. About time too, I have only had it for 2 or 3 years now. I actually already did a conversion 11 years ago but didn't like the way it came out. This time it will be better.
Chris '75 911s Targa |
I have Fred's panel and have just not got around to doing the job. I was trying to figure out if I needed some sort of pigtail connection from the current wires but it looks like you just crimped each group to a spade connected and coverd the with heat shrink. That looks to be an easier way to do it. I think you have inspired me to get this done.
1989 Cabriolet 1970 911E Sold |
Why do you do this?
Tru6 Restoration & Design |
Better design. Better fuses, better connectors, better connections.
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
