Fastest buid ever ;)
Nice project - good luck with the final stages. A great example of a car you can do as you wish with. I think the color is fantastic, but would remove the side graphics. |
Subbed
Quite the opening stanza
I have the stripes on one side today so I will see when I get it out which side that looks best. Maybe I'll have a voting about it later on ;) |
very nice work! Subscr....
The work in the car has been standing still since I decide to invest so that I could Powder coat on my own in the garage which led to some other work in the garage.
I needed some extra workbench area for the new oven and my new home made spray booth. http://forums.pelicanparts.com/uploa...1424940942.jpg But now I'm finished and it is time to start working on the car again. The car is now ready for installation of the engine. All the electrical wiring is there and also fuel lines etc. I will need some help from you guys when it comes to installing the engine wiring. I have a harness from a -83 in the car and I’m installing a 3.2 engine (with engine harness) so all the help and tips that I could get is highly appreciated!! What do a need to do with the wiring!? The engine looks a little bit sad but is on good condition and I will install everything to check that it works before I start fixing up the ingine. http://forums.pelicanparts.com/uploa...1424940922.jpg |
WOW!!!!
That's all I can say.... WOW |
Very nice!
I like the little details, like the body colour gas cap |
Beautiful car, very nice work!!
Nice build .. Here's mine,
http://forums.pelicanparts.com/uploa...1424965306.jpg |
The Hulk is awesome!
Mycket bra:-) jeg gjør nesten det samme i Norge nå, en 1976 911 bygges om til 993 Rsr, så inspirerende å se hvordan du har gjort det. Hva gjorde du med kanal-skjørtene, lot du de gå inn i dørterskelen eller kuttet du av kanten på skjørtet øverst? Håper du skjønner Norsk ;)
Ummm awesome! Cont on..
Awesome job thanks for sharing,a great motivator for me
Porsche Passion!
Thanks for all the comments!
I am speechless. WOW
The rocker panels, did they go inside the door-sills, or did you cut of the lip on the top of them, and how did you fasten them on the top edge. Glue? |
Grymt bygge!
Keep up the good work, car looks awesome ! |
I kept it and it looks like this: http://forums.pelicanparts.com/uploa...1425027384.jpg You can see that it is two clips in this pic: http://forums.pelicanparts.com/uploa...1425027755.jpg The plastic clips is from Volvo, very strong but also easy to remove if needed: http://forums.pelicanparts.com/uploa...1425027394.jpg |
