-   -   911 Targa/993 Coupe RSR project, The hulk! (http://forums.pelicanparts.com/porsche-911-technical-forum/852379-911-targa-993-coupe-rsr-project-hulk.html)
Speedster_ 03-08-2015 11:12 PM
After some research and wiring digging I found after putting all the info of the donor car together that I probably have the rear part and wiring from an -85 turbo look car (I was told that it was an -83).
So with the right wiring diagram everything was a lot easier… All the colours in the rear connections to the engine is connected and every colour matched from the beginning. I also found the connections for the three cables in the front so no need to cut any cables :) I also started connecting all the gauges and I think that I got 99% of the functions to work, the last check would be when I start the engine.
Thanks for the wiring help so far!
http://forums.pelicanparts.com/uploa...1425884591.jpg
http://forums.pelicanparts.com/uploa...1425884679.jpg
Buechsen Gustl 03-14-2015 07:11 AM
Nice project... any updates?
wachuko 03-14-2015 07:28 AM
What a great, documented, build!!
Speedster_ 03-15-2015 10:55 PM
Thanks!
I’ve done a lot of work but nothing that is interesting to show in pictures…
Light in front – OK
Hazard light – OK
Gauges connected – 99% OK
Engine harness – OK
Now it’s time for start merging the 911 rear light wiring to the 993 lights.
I’ve also dismounted the engine again to mount a new starter ring, the powder coated valve covers, new hub G50 sealings in the gearbox plus the new G50 hubs. After that is done its time for test start!! But the parts haven’t arrived yet…
I did a time lap video this Friday when I took the engine/transmission out. I’m staring ti get the hang of it, 35 minutes this time :)
<iframe width="560" height="315" src="https://www.youtube.com/embed/IQxWQjS31rY" frameborder="0" allowfullscreen></iframe>
etip 03-19-2015 01:31 PM
Wow!!!!! I am so impressed with your work! Awesome....
drknauf 03-19-2015 01:41 PM
lovely job 8)
Kaizer 03-19-2015 01:41 PM
Excellent work!
I wasn't sure on the color at first, but now I can't imagine it being anything other than green!
You're doing us Swedes proud! SmileWavy
parnelli 03-19-2015 02:06 PM
What color of green is that? Is that Viper Green?
333pg333 03-19-2015 02:20 PM
Beautiful workmanship and attention to detail. Great skills!
My only 'question' would be on the cage. Not a fan of those bolted joins.
Also do you have any future plans to upgrade the motor? Up spec to an RS type layout or even turbo?
vansicklenmi 03-19-2015 03:35 PM
tell me about those blue oil line mounts!
911GT2 03-19-2015 05:36 PM
Nice project !!! Congratulations
0-60Motorsports 03-19-2015 08:19 PM
Awesome work and project. Can't wait to see this completed.
totle 03-19-2015 10:14 PM
Tjena
Great Project. I like your attention to The details and that you do all stuff yourself :-)
I have also powder coat kit, glass blasting cabinet etc in my garage.
Love the entire process
Keep it up:-)
Where in Sweden are you located ?
Speedster_ 03-19-2015 11:16 PM
Thank for all the positive feedback!! It gives an energy boost!
Originally Posted by Kaizer (Post 8538186)
Excellent work!
I had a headache before I choosed it, but now I have no regrets :)
My plan was Viper green but after a test paint the colour looked to “old”/pastel for the 993 body so I went with RAL6018 which is close to Kawasaki green (a little bit darker).
The joints in the cage are approved for racing but of course it’s not the same as a complete welded cage but this is not a pure race car ( http://finess.se/media/com_hikashop/upload/dsc_0452.jpg ). There will be a lot of summer cruising also! I have not decided what to with the engine yet. The first plan is to get the car approved and test that everything works before upgrading. A 3.6 or a turbo would be great. It is a light car so 300hp would be enough. If anyone have a upgrade for my engine for sale, let me know!
They are made for mounting the lines together to each other. I drilled the hole out so that I could attach them to the body instead. You can find them on ebay!
Originally Posted by totle (Post 8538677)
Tjena
Keep it up:-)
Thanks, I’m located in Göteborg.
It’s a lot ow work right now with the wiring to get the 993 lightning connected to the 911 wiring etc… Not to exiting to photograph ;)
http://forums.pelicanparts.com/uploa...1426835400.jpg
Finally the hubs have arrived and have now been adjusted to the right length and G50 sealing in the gearbox.
http://forums.pelicanparts.com/uploa...1426835409.jpg
New clutch, starter ring, sparkplugs etc. and the engine is now in the car again! Hopefully there will be a test start next week.
http://forums.pelicanparts.com/uploa...1426835418.jpg
BimmerDob 03-20-2015 10:33 AM
Great thread!
Clnvwe2 03-20-2015 12:33 PM
👍 Thanks for sharing.
EliteThink 03-20-2015 05:14 PM
fantastic job!
steve rush 03-22-2015 05:34 PM
Thank you for the share, had a '76 with similar paint color...only comparison...yours is exceptional
1967 03-23-2015 08:15 AM
Excellent, fantastic, magnificent job, very well done!
Regarding the Porsche stickers I vote that you put them on, its a perfect match to your car.
Fatsorider 03-23-2015 02:16 PM
Bad ass labor of love. Just wondering. How many total hrs to this point do you have invested. Keep us posted,
