PRE-H20's Avatar
Turn Signals Fuse
Can anyone show me where the turn signal fuse is on a 1974 911?
picture would be the best.........
my turn signals stop working so i figured i would start at the fuse...... just need to locate it.
fuse box is driver side under the hood.
thanks in advance.
Old 02-25-2015, 12:55 PM
ROW '78 911 Targa
timmy2's Avatar
Relay for the flasher is fed by fuse 17.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-25-2015, 07:24 PM
PRE-H20's Avatar
You wouldn't happen to have a picture of our fuse box would you?
Old 02-25-2015, 07:39 PM
ROW '78 911 Targa
timmy2's Avatar
There are a lot of fuse box photos in this thread:
Cheap and easy ATO fuse block installation
Start by seeing if you can download the '74 schematic from here.
1977 Wiring diagram-Will e-mail fo' free
The fuse box for your 1974 car has 19 fuses in a row. Number 17 should have a Red/Black wire to it from the flasher relay. It is called S17 on the schematic.
You might want to read up on this as well.
turn signal switch quick fix pictures
Dennis
Old 02-25-2015, 09:06 PM
