tquaglino's Avatar
Ugh... drivers side window switches.
1985 Carrera coupe
When repairing the Drivers side window slider I had to remove the 5 prongs attached to the window switches. The left hand switch ( Drivers side ) wires stayed in position and were easy to reattach
the right switch ( passenger side lift ) became twisted and when I guessed on the configuration The window went half way up and then the fuse blew.
How can I figure out which wire goes where on that switch now.?
Thanks porsche for not using a single cluster plug!... Help.
Old 06-20-2012, 06:46 AM
Dublinoh's Avatar
Here is a schematic courtesy of another Pelican's post:
Power Window Switch schematic
Old 06-20-2012, 07:22 AM
Dublinoh's Avatar
Check this thread might help :
Window switch woes!
Old 06-20-2012, 07:25 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Window switches.
I posted this a while back.
For our '86:
Hope this helps.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-20-2012, 11:32 AM
tquaglino's Avatar
This is genius. Thank you
Old 06-21-2012, 07:17 AM
Layno's Avatar
Thank you!
Old 05-27-2015, 07:24 PM
Oh Haha's Avatar
I hope my fix will help another DIYer out. No cost and only took about 15 minutes.
The switch for the PS window on the driver's door has been acting up by not moving the window "up" for a while now. I could make it work by pulling the switch out of the door a bit but that began not doing it in recent weeks. The "down" function worked fine.
Today I pulled the switch out and saw that I could operate the PS window by moving the connector for that function every time. Leave it alone and no function. It was loose and not making contact in the housing.
I removed the switch and pulled the spade connector out of it, cleaned it up with emory cloth and reinstalled it. I squeezed it into the housing with pliers so it was seated securely. Bingo!
It works every time.
I could have replaced the switch but new ones have a different finish and I wanted to keep them matching on the DS. The PS switch is new(a few years ago) and has a textured finish. Not a big deal but it would have bothered me.
Pacific Blue
Wayne
Old 06-04-2015, 07:25 AM
TheSt|G's Avatar
I believe this was my passenger side on my '85:
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 06-04-2015, 07:50 AM
universeman's Avatar
Do the new switches have the smooth finish, or do the new ones have the textured finish?
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 06-04-2015, 08:20 AM
Oh Haha's Avatar
I bought a new one from Pelican about 5 years ago and it had a texture to it versus the smooth finish of the originals.
Pacific Blue
Wayne
Old 06-04-2015, 08:23 AM
Member 911 Anonymous
DRACO A5OG's Avatar
PAG OEM has copper connectors vs aftermarket crapola are silver colored tin connectors. OEM holds up much better, already replacement my aftermarket ones.
'85 Carrera Targa
PCA/POC
Old 06-04-2015, 10:29 AM
