gliding_serpent's Avatar
How much power through a 70's 4.43 ring and pinion?
I have run into a bit of a curve-ball with my rebuild. 1984 911 3.2 - The beginning of the end
In short, I have found out that my 915 3.2 has a 76 7:31 (4.43) close ratio ring and pinion. This is a good thing... so long as it can handle my planned ~260hp 3.4L, mid-range torque heavy, SSI setup.
I did some searching to try to get reliability opinions, but get my own post in the search, and a number of posts copy/pasting info From S. Zimmerman comparing ratios and weights of the 915 vs G50.
My ring and pinion is ok I believe (no pitting of the hardening, but some mild scoring). I am fully aware of the cost of a good ring and pinion from Guard, and the cost of the labor to install. Options in my head are as follows...
1. Keep what I have so long as others have experience with reliability with the power levels I will be putting down. Could be "false economy" in a new engine/tranny rebuild.
2. Go for a standard used 3.88 which should be a bit more reliable.
3. Go for the full monty Guard unit.
Thoughts and experiences appreciated. My education would suggest that options two or three would be best.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 02-28-2015, 04:10 PM
CBRacerX's Avatar
I ran one for years with a 300HP race 3.0. No issues. You should be just find, keep good oil in the trans.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 03-01-2015, 05:34 PM
Reassuring to hear.
Old 03-01-2015, 10:57 PM
Max Sluiter
Flieger's Avatar
The power rating is more limited by the heat that the gears see, so coolers and pumps and spray bars can give you more power capacity. The killer is torque, since that is based on the pure strength of the gear shape and material. Even with all the cooling in the world gears won't gain much in torque capacity, but you can spin them faster.
Old 03-02-2015, 07:55 AM
3.6L sc conversions killed second in two of our local cars. Thus i will spring for something from guard for second.
When the poster above said 300hp from a 3.0, i figured that he gets that from rpm more than torque, but that we might be in a similar ballpark.
Good point on cooling... Yet another thing the euro cars of our era had that we do not.
Old 03-02-2015, 09:47 AM
Bill Verburg's Avatar
I'm curious as to what 915 you have. Most '76 would have come through w/ 8:31 but there were a few 7:31
Sooooo, what model is it? 915.??
Bill Verburg
Old 03-02-2015, 09:56 AM
Under the radar
Trackrash's Avatar
A reinforced or HD side plate and one piece bearing retainer should help.
If you are drag racing all bets are off.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-02-2015, 10:10 AM
CBRacerX's Avatar
Correct this was a 6-8K powerband motor. I did not cool the 915 Aluminum trans but did change the swepco often
Chris
Old 03-02-2015, 10:32 AM
