Patronus's Avatar
Which Fuchs to use on the track?
I have a '85 Carrera with 7x16" Fuchs front and 8x16" at the back. Somebody told me that 15" Fuchs are 'faster' than 16". Is there any truth to that? Do they weigh less or what? All I can think of is the fact that the diameter is different.
Reason I'm asking: I need track wheels for my car and was thinking of getting 7x15" and 8x15" since the tyres are more affordable.
What do you guys use for the track? Should I stick with 16"?
Old 10-27-2002, 05:12 AM
Irrationally exuberant
ChrisBennet's Avatar
The 15" ones are often recommended because they effectively lower the gearing with their smaller diameter when used with lower than stock profile tires. Investigate track tire availablility in the sizes you are interested in before making up your mind.
-Chris
Old 10-27-2002, 05:30 AM
feelyx's Avatar
Make sure the 15's will clear your brakes also..
Tim in Sac
Old 10-27-2002, 05:59 AM
Go Gators!
s2per's Avatar
I use the same combo you're talking about on my SC. Kumho makes some great track tires in 225/45x15 for the rear that actually have a slightly lower diameter than the 205/50 fronts. If you haven't put massive brakes on your car, they'll work just fine.
Timothy Stoops
Air '62 356 B-‘86 911 Cab
H2O '12 Cayenne
Old 10-27-2002, 07:47 AM
Chuck Moreland's Avatar
15 inch will work fine with Carrera brakes. I use 15 inch.
Not only do they lower the gear ratio, reduce rotating and unsprung weight, and cost less - they also lower the height so you will get less body roll.
Chuck Moreland - elephantracing.com - vonnen.com
Old 10-27-2002, 08:05 AM
Super Moderator
cstreit's Avatar
15's will lower the gear ratio's slightly, if you get the proper aspect ratio tires... If you don't you'll have taller, more flexible sidewalls to contend with...
The only decent track tire made in a 245/xx/15 is Hoosier... No one else makes a good radial track tire...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-27-2002, 12:25 PM
