A/C thermostadt switch
I have been working on my 85 911 A/C and it is charged and ready to go but the thermostat switch on the left of the blower switch does not seem to engage or disengage. I know where the A/C fuze is and the Blower relay is but is there a separate fuze or relay for the thermostat switch? Thank you, Nick
Old 03-17-2015, 09:26 AM
Thermostat switch
there is a relay is in the smuggler box attached to the wall on the co driver side...
Old 03-17-2015, 09:37 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse #2 is the A/C switch.
Check for voltage on both sides of the fuse.
Let's hope that the capillary tube has not been damaged.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-17-2015, 09:39 AM
Barrpete's Avatar
The contacts inside the thermostat can get a bit corroded and prevent it from working. An easy diagnosis is to bypass the switch by jumpering the 2 leads to it. If that turns on your compressor then you know the switch is your problem.
If the capillary was damaged as Gerry said then your switch is toast and you need a new one. If it's just dirty contacts they can be cleaned to fix the switch.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 03-17-2015, 09:46 AM
kuehl's Avatar
nick,
go to these links on subject;
A/C wiring questions
AC Switch - only full setting works
Trouble Shooting the Porsche Air Conditioning System
Porsche Kuehl Evaporator Fan Variable Speed Controller
Old 03-17-2015, 10:55 AM
Thanks!
Old 03-17-2015, 01:03 PM
