El Duderino
tirwin's Avatar
Removing omega spring?
How do you remove the omega spring from the splined shaft at the end of the release arm? This thing is on tighter than Dick's hatband!
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 03-17-2015, 05:01 PM
Senior Member
Jdub's Avatar
Dremel it off, being especially careful not to injure the shaft splines in any way. The spring is toast, so make sure it takes all the stress in removal. The new spring will be a nice interference fit.
EDIT: So Dremel it off means using a Dremel tool's small round cutting saw and I remember going slightly diagonal in the cut, just barely cutting through the individual (last, really) spring sheathes (sp?). Then judicious use of two small screwdrivers to break the cut and gently pry back the spring from the post.
'78 Targa in Minerva Blue
Old 03-17-2015, 05:12 PM
El Duderino
tirwin's Avatar
Got it. I'm almost done now. My wife just informed me I'm making too much noise so I'll finish tomorrow. So close! :-/
Thanks for the tip.
Old 03-17-2015, 06:25 PM
Member 911 Anonymous
DRACO A5OG's Avatar
For the new one, use a bunch of washers, tape together and use a VISE or C-clamp to press it on
'85 Carrera Targa
PCA/POC
Old 03-18-2015, 08:04 AM
Some models (like mine, an 82SC) have a small, frustrating pin at the end of the shaft that's holding it in place.
Babak
Old 03-18-2015, 08:53 AM
Undocumented User
McLaren-TAG's Avatar
They're much easier to remove when they've already broken off.
Old 03-18-2015, 09:10 AM
El Duderino
tirwin's Avatar
Yea, this was part of that "while you're in there slippery slope"...
Old 03-18-2015, 09:48 AM
