OsoMoore's Avatar
Originally Posted by wwest View Post
I would suggest disassembling yours first just to be sure it's rebuildable.
How the heck do I get this stupid vacuum advance unit off? All I can find online is "wiggle it" and I've wiggled and jiggled, but its not going anywhere.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 04-19-2015, 04:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
wwest's Avatar
If I remember correctly there is a snap ring, covered by cotton wadding, inside the hollow shaft that must be removed. Then the screws holding the pickup coil can be removed....
Old 04-19-2015, 04:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
OsoMoore's Avatar
I'll keep tweaking at it. I am soaking the Timer Core (811) overnight and hopefully it will come off easily tonight. I couldn't get it yesterday.
Old 04-20-2015, 06:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
OsoMoore's Avatar
Opened it up! That pin at the bottom is a huge pain. I had to drill it half out before I could drive it out with a punch. Inside there was a lot more filings, and what looks like pieces of a shim. Here are some views of what was inside.
The complete set of bushings, clips, etc. In order so I can reference it later for reassembly.
The bottom, which seemed in pretty decent shape. However the shim that lies on this surface was partially disintegrated. See the picture three pics below. The shaft spins smoothly in this hole, and has no side-to-side play at all.
The shaft's guts. They were super dirty and quite nasty over all. I took it the rest of the way apart and cleaned it with paper towel.
The guts! The bits were scattered throughout, from the vacuum advance to the bottom of the housing. The spacer-thing was between the bottom of the housing and the first thing on the shaft inside it.
Questions!
1) Is this mess possibly the cause of my erratic firing?
2) How should I best clean this out?
3) Does anything expensive look damaged?
4) Should I disassemble the weights and springs? They seemed to move well, but there is junk scattered through the mechanism.
Thanks everyone - this is quite a chore but not as bad as the transmission last summer...
Old 04-20-2015, 04:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
ROW '78 911 Targa
timmy2's Avatar
As long as the body and shaft are not worn you should be ok with new bushings and shims. Contact cleaner is what I used when I did mine.
Removed all the nasty old grease from the weights area.
Old 04-20-2015, 05:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
OsoMoore's Avatar
I'm checking with PartsKlassic to see what they can send me for new inner parts. I'm hoping that the old bushings don't need removal, but we'll see.
Old 04-21-2015, 07:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
OsoMoore's Avatar
Talked to Kurt at PartsKlassic. He's a very helpful guy, spent 20 minutes on the phone with me walking me through parts of the system. Based on where the arcs are jumping, it is probably the coil which is failing. I am planning to replace just the top bushing, as things were generally working smoothly. Along with that, I'll replace shims.
Any ideas on what best to re-lubricate it with? Also, does anyone in the Milwaukee area know of a good shop to remove the old bushing and put in the new one? It would probably need to be reamed as well.
Old 04-21-2015, 08:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
wwest's Avatar
The random sparks were undoubtedly the result of the metal filings closing the magnetic path between the reluctor and the pickup coils armature.
On the other hand the oblong wear of the spacer indicates side play/travel of the dizzy shaft which might close the gap between the reluctor ring and the pickup coil's armature. Look for metal "strike" points on the inside of the reluctor ring and the outside of the pickup coil's armature.
Old 04-21-2015, 10:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
OsoMoore's Avatar
Distributor is cleaned and back together. New shims and so forth. She has no slop and spins smoothly. I hooked it up, in addition to a new coil. However the engine is not starting at all. No sound of combustion. Just the cranking. CDI box is whining.
It was running before, and everything I've done is electrical. So I can probably assume it is a lack of spark. Right now it is 34 degrees out there, but I am thinking I should start at the CDI and start checking things.
I replaced the green wire in the same swath of changes since I previously had it running. I had checked the green wire's conductivity through the new connection, and didn't find any issues.
Things I am thinking about checking:
1) Take off the cap and turn engine to TDC. Make sure distributor rotates and is lined up properly to the mark on the distributor.
2) Put a spark plug on the coil's output wire and check that it is sparking there.
3) Swap back old coil. Maybe new one isn't working right?
4) Pull distributor out again and re-check continuity between green wire end connector and CDI connector.
Any other ideas are appreciated.
Old 04-26-2015, 04:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
wwest's Avatar
2. First.
No spark, check continuity, measure resistance of dizzy PU coil from/at CDI connector.
Spark, then 1.
No start, ????
4/1
Old 04-26-2015, 06:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
ROW '78 911 Targa
timmy2's Avatar
Show us a picture of how the rotor looks at #1 TDC in relation to the mark on the distributor body.
Very easy to be out a tooth. (Ask me how I know)
Leading edge of rotor as it turns counter-clockwise, should be just nearing the mark with dizzy in mid adjustment range at the hold down bolt.
Old 04-26-2015, 07:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
OsoMoore's Avatar
I checked for spark on a plug - No Spark.
Hooked up an old spark plug wire to the coil directly (in place of the coil-to-distributor wire) - No Spark there either.
PU - Pick Up? I'll pull the coil and check these wires next.
As requested, here are pics. I have had the dizzy out a few times before and I'm pretty certain it is aligned just where it was before.
Old 04-26-2015, 12:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
OsoMoore's Avatar
I adjusted the timing bolt after the 3rd picture to make sure the contacts were aligned. Still no success. I'm thinking the pickup may be the issue. I tested the continuity before, right after I did the connector splice. But I haven't tested the whole system since.
Old 04-26-2015, 12:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
OsoMoore's Avatar
I pulled it back out and sure enough, my connection for the new PU wire was bad. Fixed the connector!
However I forgot to put it in TDC before I pulled the dizzy this time. Soooooo 50/50 chance it? Or is there some secret way to know?
Old 04-26-2015, 01:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
ROW '78 911 Targa
timmy2's Avatar
For sure way is to find #1 TDC with #1 plug removed and using a depth gauge (Plastic stick) feel for the correct position when the piston is at it's highest point on compression.
Worked for me when I had to pull the dizzy and then the engine rotated.
Or, 50/50 it...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-26-2015, 02:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
OsoMoore's Avatar
50/50 did it!
Everything seems to be working great. Ran her around the block a few times (including giving a neighbor kid a rid and "the car talk"). No bouncing tach, no arcing noises.
I can't be sure if it was the coil, the pickup wire, or the messy dizzy. But all of them needed love, and now all of them are happy. So I am happy.
Thanks everyone!
Old 04-26-2015, 02:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
wwest's Avatar
Video of the test.
Playing forward.... more
Can physical contact of the alternator rotor with the stator due to "impending" bearing failure cause enough EMI/RFI to "misfire" the CDI? Even with the VR depowered?
That certainly begins to appear to be a possibility...
Old 05-16-2015, 09:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
