MAF readings - non linear
1986 911 3.2 - no cat - is running like crap. dies at lights, (intermittently) surges from low rpm acceleration (intermittently) seems like it is running hot (but oil temp is ok)
I became suspicious of the MAF. After testing I am almost more confused. The ohm meter is always getting a reading but the readings seem like they are oscillating. Temp side checked out perfectly. Any suggestions? Thanks! Andrew
86 911 Carrera Last edited by AMSRoadRunner; 03-24-2015 at 06:33 PM.. |
Chain fence eating turbo
I didn't know '73 911's had MAF's.
I assume you are talking about the 86? Have you seen the deal on the wear groove on the circuit board? You have to bend the sweep arm to a fresh spot? Might be worth popping the cover off to see if it looks like its worn through. There is some information posted about the procedure and details if you search.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Diss Member
Technical whiny bit: The 3.2 doesn't have a Mass Airflow Sensor. It has a "barn door" Air Flow Sensor...
The air flow sensor isn't doing anything at idle. When the idle switch is contacted it is all on the idle control valve to meter air. You can test the switch easy enough to be sure the DME knows to go to the idle circuit. You can also see if the throttle is releasing enough that the switch is engaged. There are a number of threads on testing the idle control valve you can search on. But ... Lots of things to test but I'm suspicious of a vacuum leak in the intake gaskets. Check that the allen bolts are torqued to 18 ft/lbs. Even if it is torqued correctly it still could be cracked gaskets. Easy test is to get an IR thermometer, put the car up on jack stands, start the engine while cold and after 15 seconds or so get the temps of the various exhaust ports. They should be pretty equal. If there are cold ports you know that something isn't burning there. A misfiring plugs and bad injectors could also show up as a cold port.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Go here Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com Very good procedure involving a 9V battery to test the AFM. The Ohmmeter is not using enough current to get reliable readings. Once the test with the 9V battery shows flat spots follow instructions on how to try and fix that by:
- Adding a wire to improve the contact between shaft and wiper - offset wiper position on thick film resistor to address wear on resistive track Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Slippery Slope Victim
I sent my AFM to Bavarian Restoration, they provide a data sheet of the refurbished unit. THe engine is very happy and linear in acceleration and idle beautifully.
BTW, I also sent my DME to Ingo (Ischmitz) to be evaluated and the necessary repairs performed as needed. Although the car ran very well prior to this work, Ingo found, under microscopic imaging, potential fissures developing in the solder joints which could lead to intermittent conection problems. As our cars are approaching 30-35 years of age, I thought I would be proactive in heading off any potential problems down the road.
Mike˛ 1985 M491 |
Smoove1010
Bumpy idle, acceleration flat-spots, hesitation, idle hunting - these are all popular topics on the forum, and there are many posts. They seem to fall into two categories - vacuum leak troubleshooting and AFM troubleshooting, though the posts go off on many related (and sometimes pertinent) tangents. Here are some threads that I found to be valuable.
Vacuum Leaks: vacuum leak you probably didn't ever think of Vacuum leak - check your brake booster line Another Vacuum leak question Stop SMOKIN! The Cure 3.2 AFM, AFR & Idle Adjustments idle bounce 1986 911 idle surge Euro 3.2 Air/Fuel Mixture ? It might be worthwhile to search for threads on the idle control valve and idle switch - these are two of the basics that are very easy to test. Here's how I solved similar problems on my bucking Carrera: AFM Mixture - Am I That Lean? Good luck! GK
1987 3.2 911 Cabriolet Grand Prix White Exterior Five Shades of Burgundy Interior |
Diss Member
^ +1 ^
Great post Smoove1010! "Test, Test, and when done TEST!" (I hate seeing people throwing parts blindly at problems.) When I had my "Rubber Explosion®" incident I discovered more then one hose with large cracks in it behind the throttle body. There are a lot of hoses and swaged fittings back there hardening over time!
Where can you hook up a Vacuum Gauge to check for a leak and what readings would you expect to see if you had one? 86 911 like the OP
^I figured he must of changed his sig :-) I was thinking "What does Tippy know?" Is there a story here....hmmmm
Thanks for all the helpful leads guys!!
Update: I tested the MAF as per: Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com then I had a beer and tested it again with the same results. Voltage bounces all over the place and drops off when wide open. ![]() Not looking good for my MAF. Going to give Bavarian Restoration a call in the AM. I feel like that is my best bet. (I know, I know perhaps not the best place to talk about my feelings.) Andrew
86 911 Carrera |
I apologise if this is rubbish, but I remember testing the barndoor flow meter in either my Toyota MR2 or my GTiR and it does indeed have an oscillating signal and that is correct.
In those cars the signal is not supposed to be linear.
We own 4 cars - the truck is the only one with the engine in the front! PCA member since 1983 |
