Replacing 3.2 Distributor Cap
I'm sure this is trivial, but I'm having a devil of a time removing plug wires in preparation to replace the distributor cap in my 3.2. There's not a lot of maneuvering room in there, and I'm afraid of breaking something if I just try to horse the wires out.
What's the approved procedure? Do I need to remove the two air channels (arrows), then the cap and then the wires? Thanks in advance.
Member 911 Anonymous
Remove the big banana pipe/hose. you will have more room to work.
Twist and pull only on the connectors. On the new cap, use dielectric grease so the plugs will seat properly and all the way. You should hear an audible click. Use a pick tool to get any air out of the plugs. That's it. Take careful not of each plug.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
And keep the grease off the contacts, it's an insulator despite what you may have heard.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
If you're planning to re-use the wires, I wouldn't rule out disconnecting them, taking the cap and wires to your bench, and twist/ pull them out of the car. Twist the plug boots the tiniest amount just to get them unstuck, without breaking the wire crimp connection.
There are plug boot grabber tools out there. pliers with curved, rubber coated ends.
These save a lot of frustration. Straight and angled available.
Slippery Slope Victim
And putting the cap back on is a PITA. The springs on the screw are tough to push and turn to lock.
MikeČ 1985 M491 |
Thanks, everyone, that will get me going again.
