Ignition Coil Recommendation/Help
I've searched around the forum, and need some help or recommendations on which coil I should go with.
Working on a tune up on my 81 SC: plugs/wires/cap/rotor, etc. Currently have stock ignition setup, however would consider upgrading in the future. That being said, can/should I go with something like a Flamethrower or MSD with my stock setup for now, with upgrading in mind? Looking for help understanding pros/cons. Thanks! |
Fleabit peanut monkey
They are pretty basic coils. I have an MSD Blaster coil that is 12 years old but I do have the MSD box.
Set your plugs at factory gap. If you do upgrade to MSD/Permatune/other, don't go nuts on the gap even though they say 60 thousandths is do-able. Lots to read if you search. You want your car to run smoother? Replace the Lambda box relay under the passenger seat. That 1 inch cube thingie attached to the silver box. Get the Porsche / Bosch one. It's pushing 35 years old.
1981 911SC Targa |
ROW '78 911 Targa
MSD blaster II high vibration coil is what I have been running for 3 years with stock CDI box.
Hilbilly Deluxe
Been running a pair of them for about 8 years now. Direct replacement for the Bosch coil, and while not an "upgrade" they are a lot more reliable than the current crappy made-in-Brazil Bosch coil.
CDI systems should use a transformer type coil not the old style inductive type.
Simple and inexpensive upgrade.
Hi wwest been thinking of upgrading my coil just to see if mine is getting tired its the original would this be a good upgrade for my 73t with the 2.4 and the 3 pin cdi box
And if so any idea of part number and we're to purchase. Thanks Mike |
Coils don't get "tired" but if you looking for an excuse to spend some pocket change you could make a worse choice.
CDI systems can always benefit from use of the proper coil. |
Hilbilly Deluxe
The advantage of the MSD Blaster over that Accel Coil is mounting. The HD blaster fits in the factory location, and if you take the label off, looks like a Bosch black coil.
Thanks, with either the MSD blaster or the ACCEL coil do you have to make any other changes or simply remove the old and replace with the new. Another reason for changing is to have a spare.
Thanks Mike |
El Duderino
MSD is plug and play. With the Accel coil you will have to modify your mount somehow. The MSD coil is slightly taller than the Bosch so you may need to push it further down in the mount, particularly if you have an A/C condenser.
I think wwest used the Accel as an example. Normally you have a + and - ring terminal on the coil going to the CDI. I don't see how that would connect based on that picture. Not saying it couldn't work but it would require some investigation as to what would be necessary to make it work. Consider that if you wanted to leave it in the stock location you would likely need to mount it on it's side OR you would need to mount it near the fuse panel/CDI which would mean you would need to lengthen the wires. |
Thanks for all the recommendations. I was already leaning toward an MSD, however it looks like thats what'll I'll be adding to the shopping cart right away.
Thanks tirwin looks like the MSD is the better choice for my application when wanting to use my old as a spare
Did the Blaster upgrade too, as my original had a jb weld repair to one post , and it was oozing goo allover my distributor.
If you use it with a Bosch CDI be sure to get the one with the ballast resistor. -C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
partsklassic has a new kit that looks just like the original but with newer better comonents and looks stock. They have coils too.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Please explain..
+++++on that. Their ignition stuff looks great! The CDI box is awesome and looks OE.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
compound. Bosch CDI is a magnesium casting.
Dave |
ROW '78 911 Targa
You would need to take it all apart to install that wire. You have to take a section of the main harness apart to install the tach wire in the 14 pin connector. You would need to take theirs apart to install the safety switch wire. Or, run without the pump cut out. I let them know about the missing wire in their harness. (wiring color codes and wire type don't match either)
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
I'll snap a photo today and post. -C
| Tags |
| coil , ignition |
