 Anyway are you putting or have plans to install into your 930? That weight is low which is good but what about the condenser size surface are dimensions 930/s with large enter-coolers reallly cut down a/c system heat exchangers room and makes it even more of a challenge to make cold a/c  |
			 Chain fence eating turbo
			I have a turbocharged Carrera 3.2 still narrow body.
	But yes, my intercooler is full bay (width).  |
			I just meant, I remember reading the Lotus Elise AC system was designed super lightweight, not that I'd use one.
 Anyway that makes things HARDER BUT not impossible, although I have not installed one yet I have A small PFC for 930s 1/2 upper deck lid space, and you would still need my front PFC But why would you want to put in a lotus a/c system? or chaNge from Porsche's 911 design? not sure if that would work for you but it might?  |
			 Best friend is my dog
			I agree with you KelogGes, new AC systems/components are becoming super light weight and extremely compact.  Not to change your thread but, the compressor on a brand new Scion FRS is not much bigger than a coffee cup.  In addition, there is not much to their condensers.  That's what is great about new technology as it is always in constant change for the better.
 YOU need to use your smugglers box for evaporator OEM plastic box is designed to fit it then it can be modified you dont want to make an abortion a/c The Tan Swan the Father that first had because he lived in pacific nothwest and you don't need a/c there hacked the firewall and the duct-work under the dash to put in a 12 volt heater and tossed out the a/c What a friggen pain his hack job caused and a lot of labor to fix it, The Tan swan took months of work ouch but now it has a state of the art new technology A/C system in it all custom designed Last edited by KelogGes; 04-14-2015 at 08:16 AM..  |
 Gears turning.....  |
 Perhaps that's why KelogGes is making such a concerted effort to cool it electrically. 22 amps...  |
			 Banned
Will this actually increase 911 a/c performance past what is already widely available - not just weight savings but actual cabin cooling performance?  Nothing that you have shown-&-told thus far (over and over and over and over) has accomplished this, so maybe this "to be announced" product/idea will get you there.
			 Banned
			 Banned
I CALLED YOU A LIAR
			li·ar ˈlī(ə)r/ noun a person who tells lies. synonyms: deceiver, fibber, perjurer, false witness, fabricator, equivocator; fabulist; And I meant it and still maintain you are ! for the BS you posted here repeatedly about your car A/C system and claims is true posting so called temperature numbers pictures showing 29.x degrees and saying your evaporator does not freeze up, and the rest you said about extended driving at these temperatures I AM CALLING YOU OUT Last edited by KelogGes; 04-14-2015 at 10:56 AM..  |
			I have never posted anything but true facts here I can back up with proof !
			Prove me wrong
 you can't fix stupid!  |
