As you can see, I have my alternator out and have to wait about another month before all the parts get back to me.
![]() So, what is the best way to clean this puppy? I'm not opposed to some sort of spray cleaning liquid. I can roll her out of the storage unit too, I think! Thanks, Tom |
Taking it apart is easy
To me that looks more like corrosion than dirt buildup. Is it really dirt?
Here's what mine looked like when I opened it up, same as you. There is more dirt sticking to oil seepage in my engine than you appear to have. I didn't have running water available either when I took this picture, but after wiping off as much crud as I could I used a degreasing agent (an orange based cleaner) with a rag, then wiped it off with water from a bucket that I brought to my shop. Possibly you want a more complete 'washing' of the engine than I did, but a storage unit makes it tough. Can you place a large pan under the engine to catch falling dirt as you clean? Nothing makes the dirt magically vanish. ![]()
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
losing battle
Under the radar
What's the oil cooler look like? The cylinders and heads don't look bad at all.
abides.
+1
Just leave it
Graham 1984 Carrera Targa |
Senior Member
I would certainly have a look at the alternator ground (mesh wire to block) and clean that up, maybe consider replacing it if it is the original and hard to bend - you really want that ground in top shape and yours looks corroded to me. For now, grab some alum. polish and polish up or paint the fan - it can clean up pretty nice (for a week, anyways!).
I'd also remark that neither picture shows a center support strut across the middle cylinders (2; 5) for your air directional shrouds. Should there be one there?
'78 Targa in Minerva Blue |
Good question. I'd like to know, because I'm ignorant about this.
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 03-30-2015 at 06:51 PM.. |
That's not the same engine. What year is that?
Jdub opines:
Thanks, Tom |
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 03-30-2015 at 06:52 PM.. |
What engine do you have? See Red arrow below. Also your engine may not have the piece with the white arrow. ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Looks like I'm OK by your last post. Tom |
Thread Tools | |
Rate This Thread | |
