/ˈpɔrʃə/ PORSH-ə Fan
MSD Rev Limit Setting
Installing a MSD Street Fire CD Ignition Box with MSD High Vibration Coil in a '77 911S with stock 2.7 SSIs and M&K 2 in 1 out.
What should I set the Rev Limit at? It comes with a 100 increment adjustment set at 6600rpm stock. What should this be set at? Thanks for the help!
1984 ROW Carrera Sunroof Coupe Schieferblau 1982 US SC Targa Moosgrun 1977 US 911S Sunroof Coupe - SOLD |
I have been wondering the same thing. I have a bunch if rev limiting chips and not sure which one to use.
Chain fence eating turbo
Isn't redline annotated on the tach?
Set it at 6600 RPM since your engine has cast pistons.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks Steve! My tach is more of a orange-ish redline block showing a range between 6400 and 6600.
911SC Tinkerer
I have the same set up in my '83SC with magnecore 8mm wires and a resistorless rotor. I set mine at 6500 and haven't had an issue with it over reving. I figure a couple hundred below redline wont hurt it.
Its a great set up for the price and beats the hell out of the alternatives. -Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
Thread Tools | |
Rate This Thread | |
