THIS IS NOT A HOBBY!!!
but i guess from what you posted you have no interest Have a good day |
See, this is why it's silly to insist that you're not trying to get people to buy product. And we all know exactly why - you didn't get permission to sell your product on these pages, so you're just circumventing the rules. You're not even a little clever about it. The very insistence that you have about not selling product when it is completely obvious that you are trying to sell product is why you've lost credibility. That, and making claims like you invented reversing the refrigerant flow, or that these condensers were designed specifically for these cars. Trust, once lost, is impossible to regain. |
What time Monday will this be bumped up? |
go sit in the corner Eric!
true! http://forums.pelicanparts.com/suppo.../crucified.gif |
BLUE BIRD 86 SC Cabriolet DIY Reversing The A/C GASES
http://forums.pelicanparts.com/uploa...1462818733.jpg
The engine was finally installed into the body over the weekend It's been over a year since this project started and I made and sent my PFC matched set condensers to Gilles the owner After installing the engine it would not start, in testing it was discovered the fuel pump turned out to be defective, a new fuel-pump was ordered and should arrive this week |
My airflow measurements indicate that at engine idle the rear lid condenser gets substantially more cooling CSA airflow than the front... Above idle the effect is much more dramatic.
What makes sense to me is that the highest system pressure, highest temperature fluid, should be routed to the most efficient condenser. In this case it seems clear that would be the engine lid condenser. So why does your "reversing" the flow work...?? To make matters even worse it appears to me that your aftermarket front lip condenser, as with most others, get little, or no, cooling benefit from forward motion airflow as does the OEM. Is engine heating, IR heating, of the rear lid condenser resulting in the front lip condenser being more efficient? |
wwest go sit in the corner
Eric go sit in the corner
Wait...are you saying that YOUR Jesus??? |
to others your welcome to ask questions as long as they are polite & civil
to bashers and harassers go fly a kite |
What are the fittings on your front PFC condenser? What size?
This thread reverses my flow. |
And your answer is? And saying "have patience, Giles is working on it", is not a suitable "answer" since you made those claims of superior performance years ago and also claim your systems are up in running in a couple of Florida cars. |
putdown your crakepipe |
You claim that "reversing the gases" actually works to improve the system performance, so why not give us an engineering analysis as to why? |
You can't make this stuff up. |
| All times are GMT -8. The time now is 06:51 PM. |
