-   -   I have made a set of PFC's for a DIY'er They Will Be Installed Reversing The Gases (http://forums.pelicanparts.com/porsche-911-technical-forum/860636-i-have-made-set-pfcs-diyer-they-will-installed-reversing-gases.html)
KelogGes 04-24-2015 09:54 PM
Both these Proven Inventions USED TOGETHER will be installed by A West Coast DIY'er for the first time in his 911
The 911 A/C System will also use a Variable Orifice Valve VOV
Instead of a Thermal Expansion Valve TXV
KelogGes 04-25-2015 06:24 AM
The West Coast 86 Carrera Cabriolet DIY owner is on-board with me to also install as part of his installation besides "Reversing The Gases" Micro-Processor Control of SUPERHEAT & TEMPERATURES
mreid 04-25-2015 07:25 AM
Just for the record that's not slander, it's libel.
As in written, not spoken. Shaken, not stirred.
wwest 04-25-2015 01:00 PM
Hmmm... VOV...
Is that possibly how/why you got MINUS 3-4 PSI low side pressure during your "reverse the gases" test..??
Assuming the system was operable, no blockage to refrigerant flow upstream of the compressor inlet, how much "SuperHeat" would that equate to..?
wwest 04-25-2015 01:06 PM
Have you advised this person that the before and after testing should be without the microprocessor control installed...?
Have you considered an Iphone ap via Bluetooth for the top level control./display?
Larger customer base if the console "factory look" can be left intact.
KelogGes 04-26-2015 09:25 AM
This 911 HIGHLY MODIFIED EVAPORATOR Picture is from The Tan Swan COMPLETE A/C New Technology PROJECT I did over a year ago,
THIS IS NOT THE WEST COAST DIY 1986 SC Carrera Cabriolet 911 Evaporator!
However, the Tan Swan had “REVERSING THE GASES” #3 installed and also USED VOV technology instead of a thermal expansion valve
Note: the Tan Swan did not have DIGITAL SUPERHEAT or Temperature control; The Analog electrical controller you can see in the picture is for the highly modified evaporator & blower
This picture is posted for the WEST COAST DIY 1986 SC Carrera Cabriolet 911 Evaporator OWNER!
Note: This picture was taken during The TAN SWAN installation; The Smugglers box cover closes normally in the completed installation by carefully slightly bending the evaporator inlet tube just a little lets cover fit Perfect.
(The Larger modified Blower motor however required smugglers box cover to be modified due to the height of the larger/taller blower motor)
http://forums.pelicanparts.com/uploa...1430063708.jpg
KelogGes 04-26-2015 03:10 PM
Heat wave! South Florida breaks temperature records
TODAY Sunday, April 26, 2015
96 Degrees ambient Fort Lauderdale & Miami
99 Degrees Boca Raton
Heat wave! South Florida breaks temperature records | Miami Herald Miami Herald
KelogGes 04-26-2015 04:35 PM
Open your mind TO NEW A/C TECHNOLOGY
<iframe width="640" height="360" src="https://www.youtube.com/embed/p1wpi2o1Q2o?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
ganun 04-26-2015 04:46 PM
Yeah, it was 97 with a"feels like" of 101 in Miami, was going to get the 911 out for testing, but couldn't due to family commitments , have to watch until the next heat wave.
The other P car's a/c is great though.
KelogGes 04-26-2015 05:00 PM
HUMIDITY TODAY ONLY 45%
Heat Index = 106 F / 41 C
@ 90 % Humidity Heat Index = 158 F / 70 C
Heat Index Calculation
tirwin 04-27-2015 02:40 PM
Originally Posted by KelogGes (Post 8593765)
Everything exists in one three states, solid, liquid, or gas (vapor).
That is not technically true. Plasma and Bose-Einstein condensates are also states of matter.
Just sayin'...
wwest 04-27-2015 04:28 PM
Just sayin'...
And just where does steam, liquid on its way to becoming a gas, fit into that equation?
Ronnie's.930 04-27-2015 04:48 PM
Reid, is this you ?!?!?!
<iframe width="640" height="390" src="https://www.youtube.com/embed/AbfKFlu4K7w" frameborder="0" allowfullscreen></iframe>
Bob Kontak 04-27-2015 04:57 PM
The butt skunk will do anything to keep his thread in the top 20.
tirwin 04-27-2015 04:59 PM
You are so obtuse, it's almost cute. Almost.
Ronnie's.930 04-27-2015 05:49 PM
Hmmmm, perhaps Reid is trying to sell something in the 911 Tech forum (other than "crazy" - he's been hawking that since about 2012, buttofcourse)?!
Like this?!?!
http://i.telegraph.co.uk/multimedia/...0_1650068c.jpg
KelogGes 04-28-2015 08:43 AM
5 LBS 5 OZ's Total Weight of my new version of BOTH FRONT & REAR PFC/s
State of The Art PFC Technology custom made for early model 911's also using my discovery Reversing The Gases
CAPABLE OF 30's DEGREE A/C VENT TEMPS @ 95 DEGREE'S AMBIENT
Front PFC ONE pound .95 ounces
Rear PFC THREE pounds .56 ounces
http://forums.pelicanparts.com/uploa...1429486633.jpg
The Top PFC takes a shoe horn to fit it into the cavity between the front wheels but fits perfectly into the body <grin>
NOTICE the curve to perfectly fit the the contours of the full width of the deck lid outside air inlet on the bottom PFC so you can completely seal the rear pfc to the deck lid!
KelogGes 04-28-2015 09:06 AM
I MAKE THE MOST EFFICENT A/C HEAT EXCHANGERS IN THE WORLD TODAY FOR EARLY MODEL 911's
http://forums.pelicanparts.com/suppo...leys/kumar.gif
wwest 04-28-2015 09:58 AM
Front PFC ONE pound .95 ounces Do you really mean to say .95% of an ounce?
Rear PFC THREE pounds .56 ounces SAME....!
Are you really stating, as some readers seem to think, "A", that you get ~30dF vent temperatures with evaporator inlet temperature of 95dF, with max blower speed yet?
Or "B", you are only outing the efficiency of your condensers in providing an adequate supply of liquid refrigerant at 95dF..???
KelogGes 04-28-2015 07:16 PM
222.9 CFM EACH X 4 = TOTAL 891.6 CFM's
Front PFC
http://forums.pelicanparts.com/uploa...1430273413.jpg
http://forums.pelicanparts.com/uploa...1430273510.jpg
Bob Kontak 04-28-2015 07:50 PM
Hey, look what I am selling in the Porsche 911 Tech forum.
Look at meeee and my invention.
I am selling stuff in the 911 tech forum with no regard to forum rules or guidelines.
I will post something everyday to keep it at the top of the thread list.
KelogGes 04-28-2015 08:12 PM
http://forums.pelicanparts.com/uploa...1430276232.jpg
This front shroud and PFC only uses one large HIGH CFM blower
Requires body modification perforation
http://forums.pelicanparts.com/uploa...1430276718.jpg
KelogGes 04-28-2015 08:33 PM
nice try lol
BOB thanks for your never ending harassment and BS!!!!
WRONG AGAIN!
I am not selling anything here yet
Read the thread topic if you can read!
wwest 04-29-2015 07:54 AM
Front PFC
Didn't you inform us previously that you abandoned this idea as unworkable..??
wwest 04-29-2015 08:03 AM
Originally Posted by KelogGes (Post 8599669)
Pictures make it perfectly obvious why you need/require all that extra airflow since unlike the factory tube and fin condenser yours doesn't benefit nearly as much from roadspeed cooling airflow.
With the factory one you can use a stud mounted thermostatic switch atop the R/D (as was done in the 944/928) to disable the front blower except when needed.
Bold text by wwest....SmileWavy
KelogGes 04-29-2015 08:09 AM
Rear PFC Deck Lid FIT LIKE A GLOVE & SEALED Install Reversing The Gases
http://forums.pelicanparts.com/uploa...1430318861.jpg
http://forums.pelicanparts.com/uploa...1430318015.jpg
http://forums.pelicanparts.com/uploa...1430318207.jpg
http://forums.pelicanparts.com/uploa...1430319305.jpg
KelogGes 04-29-2015 08:18 AM
Originally Posted by wwest (Post 8600220)
bold text by wwest....smilewavy
stop editing my posts making it look like i said something i did not!!!
Make your own and quote my words correctly SEPARATE OR "DON'T QUOTE ME"!!!!!!!!!!!!!!!!
Das Schnell Ei 04-29-2015 08:21 AM
This thread makes you look like a crazy person...just saying... don't be that guy.
I dig your work.... it looks very nice!
wwest 04-29-2015 08:28 AM
Originally Posted by KelogGes (Post 8600233)
We have been "here" before....
Obviously you failed to read the bottom line...
Make your own and quote my words correctly!!!!!!!!!!!!!!!!
SmileWavy
wwest 04-29-2015 08:34 AM
Make your own and quote my words correctly SEPARATE !!!!!!!!!!!!!!!!
Single pass airflow with a 65dF temperature drop...?
You haven't yet answered that question or clarified your supposed FACTUAL statement.
Without an answer must we assume you now sign off on long term operation at sub-freezing temperature..?
Six of one, 1/2 dozen of the other.
KelogGes 04-29-2015 08:42 AM
Thanks Das
wwest 04-29-2015 08:42 AM
I wonder...
Has it at all occurred to you that improving the heat transfer efficiency of the engine lid condenser has the same adverse side effect as adding my 2 Spal fans.
Reduced cooling airflow effects for the engine..
http://forums.pelicanparts.com/uploa...1430321989.jpg
KelogGes 04-29-2015 08:51 AM
My pictures posted today are mostly for the DIY west coast owner getting my PFC's and discussions we are having about his install
THEY ARE NOT HIS 911
KelogGes 04-29-2015 09:09 AM
West go find someplace else TO SELL YOUR BS AND LIES
wwest 04-29-2015 09:22 AM
So you REFUSE to answer the question..?
Then we must take it for granted that you misspoke.
wwest 04-29-2015 09:23 AM
So your customer doesn't have a private email account?
KelogGes 04-29-2015 09:29 AM
wwest 04-29-2015 10:01 AM
Not until you "step up" and answer a few questions...!
KelogGes 04-29-2015 10:12 AM
You cant help stupid!
KelogGes 04-29-2015 10:17 AM
