Backdating the dash questions
I am thinking of a backdate of my 1985 dash to the early 1970s with the aluminum trim and basket weave. I see the aluminum trim pieces available. I was curious if the basketweave is glued directly to this or it is wrapped around a piece of aluminum and then adhered to the trim piece.
Any help here is appreciated.
Mike
Old 04-23-2015, 10:16 AM
Done! Pretty easy really. Rennline dash with added extrusion and basketweave.
Old 08-09-2015, 11:57 AM
Nice job - which Rennline pieces (part nos) did you buy? Knee pad delete now? Appreciate your help -
Old 08-09-2015, 03:27 PM
non-whiner
mreid's Avatar
Are you going to cut holes for all the dash switches or do something else?
"Too much is just enough."
Old 08-09-2015, 03:50 PM
Helix8...I have the Rennline DA67 dash delete in black for my 1985. No knee pad. The aluminum dash extrusion and basketweave vinyl were sourced from eBay.
mreid, I put two of the three switches on a subpanel where the ashtray used to be. You can see it through the steering wheel. I then covered it in vinyl. The emergency flasher switch will be given under the dash on the left side.
Old 08-09-2015, 04:07 PM
Old 08-09-2015, 04:10 PM
