Dial 911
A horse with no name's Avatar
Any reason why?
Re the large castellated nut on the bottom of the ball joint... Is there any reason why a 'normal' nut could be used instead of? Is so, to be able to remove and replace it with a 'normal' socket should be 100% better - Right?
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 05-05-2015, 01:15 PM
VW_NUTT's Avatar
typically castle nuts are locked in place with a cotter pin.
1984 Carrera
1985 Vanagon Westfalia
2009 Audi A3
2015 VW Jetta
2016 Sprinter
Old 05-05-2015, 02:29 PM
Project Addicted
It's all about available space and locking tabs. When engineers are working to minimize sizes for either weight, cost or other things, they go with what they want. There is a locking tab to accommodate too.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 05-05-2015, 02:33 PM
Dial 911
Thanks...Yes they are. How about a normal deep nut with holes located 180 degree's from one-another for the cotter key?
North American ball joints use a normal socket wrench...View on this link
http://www.summitracing.com/int/parts/mog-k6541/overview/make/chevrolet/model/silverado-1500
Cheers!
Leonardo Da Vinci
Old 05-05-2015, 02:40 PM
VW_NUTT's Avatar
I have my doubts that you could drill the hole in the correct spot before you put it on and have it line up with the correct torque. Why not just buy the correct nut?
1984 Carrera
2009 Audi A3
2015 VW Jetta
2016 Sprinter
Old 05-05-2015, 04:05 PM
Dial 911
I likely will. It's just that I have heard how hard they are to come off and the $55.00 tool that our hosts sells is for installation only...They are also $17.00 US per nut.
I'll have to look around to see if I can find the size and type of thread used on the original tie rod and then see if I can find a ' normal' socket type castellated nut. With a 'normal' socket one would have little, if any, trouble when removing it.
At the factory they have no trouble putting it on but unfortunately they don't have to try and take it off with the socket tool that is required. If they did, they would likely switch over to what the rest of the world is using, which is a castellated nut that you would use a normal socket on to remove or install.
I have a '86 911 that needs 108 ft lbs of torque, where as other years need 184 ft.lbs. of torque. I would think that this may be a bit hard to do with the special 4 pin socket.
Cheers!
Leonardo Da Vinci
Old 05-05-2015, 04:34 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by VW_NUTT View Post
I have my doubts that you could drill the hole in the correct spot before you put it on and have it line up with the correct torque...
It rarely does.
Unless there is a torque range, you torque it to the spec and keep going until you can put the pin in.
Who Will Live... Will See
Old 05-05-2015, 04:42 PM
VW_NUTT's Avatar
why not just get creative with a cheap impact socket and grinder and make it? All you need is a socket the same diameter as the nut. Or you could try Canadian tire they might have that tool to loan you. They have it at the store here.
1984 Carrera
2009 Audi A3
2015 VW Jetta
2016 Sprinter
Old 05-05-2015, 04:44 PM
DanielDudley's Avatar
If you come up with something good, let us know.
Old 05-05-2015, 04:45 PM
Project Addicted
Yes regular ball joints have essentially a bolt holding it to the spindle upright. This is drilled for a cotter pin. The 911 ball joint nut you are talking about is what holds the ball joint into the control arm not the spindle.
If you find a normal nut it will be much too tall as well. The diameter is about 55mm so the hex nut will be the same height.
Buy the proper socket and then resell it. I really have my doubts that a standard hex nut will fit.
Jon
1966 912
1986 944
Old 05-05-2015, 04:53 PM
Functionista
manbridge 74's Avatar
Not THAT hard to get them off....
Old 05-05-2015, 05:08 PM
non-whiner
mreid's Avatar
Geez, I spun mine off with an impact wrench. Easy peasy.
Get the tool on the left. It is billet, has no restrictions and is sold on eBay periodically.
"Too much is just enough."
Old 05-05-2015, 07:26 PM
ROW '78 911 Targa
timmy2's Avatar
$25 solution
Source for ball joint socket tool? (Installation)
Old 05-05-2015, 07:41 PM
Dial 911
Thank you mReid, 'Timmy 2' and manbridge 74 - I will now be able to sleep tonight. I have an impact, so the nut may just spin off also eh! Thanks to all for your input - Much appreciated!
Is this the socket - an OEM/Great Neck tools?
Amazon.com: OEM 25965: Tools & Home Improvement
Cheers!
Leonardo Da Vinci
Old 05-05-2015, 08:36 PM
ROW '78 911 Targa
timmy2's Avatar
Looks to be correct, I bought mine at the local autozone.
Maybe a trip to Bellingham is in your near future?
Old 05-05-2015, 10:07 PM
