72 911 Although it is done at the moment, it will never be finished. |
mine from FWK (german made) fit plug'n play like acharme...
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
... but what hi torque starter for a G50 is out there that the board truly feels is "plug and play" ? Just looking ahead if mine decides to crap out.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Chain fence eating turbo
Don't remember the brand of my starter (very common brand that's pretty universal), but it never took a shim.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
had for 7-8yrs or so and it has been flawless. It did not need a shim on install. Does this one look like yours?
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Hi Torque starter shim and clocking
I installed the IMI Hi-Torque starter a month ago. This shimming business I think mostly is misunderstood. The flange is thinner than the original starter, yes. You need a shim of material appx 1/8" to 3/16" thick once the starter is in position, over the stud, before the hollow allen recess nut is put on. This is to prevent the stud from projecting into the allen recess, limiting the bite your allen bit has.
I happened to make it out of 2 galv washers, and ground the edge down to clear the bump of the starter bolt. Also: change out the electrical connector. I used a crimp female push-on with built in heat shrink- auto zone Note: The clocking of the flange position to fit my 84 carrera 3.2 |
Model # of the hitorque starter
Good evening everyone
What model # do I need? |
