It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Engine install today...questions
Aloha, I have several questions, but I'll just ask the ones about the physical install now. I think I read the clutch cable and the throttle rod go above the trans mount plate, correct? I clocked my new hi torque starter to the 4th position as I have read. I installed it with the engine out, does this look right? will it fit in this orientation?
Thanks in advance. Cheers, Mike.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 05-10-2015, 04:56 AM
JOHN21BLACK's Avatar
Your correct on cables and linkage above trans mount. As far as starter. I install mine after install.
Old 05-10-2015, 05:10 AM
It's a trap...
OK thanks. I think you are right. I'll remove the starter. No sense in having to stop the install because the starter is in the way...DOH!
Cheers.
Old 05-10-2015, 05:25 AM
I always install the starter first and have never had any problems with it.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 05-10-2015, 05:37 AM
non-whiner
mreid's Avatar
I always install the starter first, but mine it clocked so the battery stud is vertical.
"Too much is just enough."
Old 05-10-2015, 06:07 AM
