Vintage914Racer's Avatar
Engine harness help
I'm trying to determine where the three wires pictured go on my 68s engine. Can anyone give me a clue? I thought I took diligent photos befote j removed it, but apparently not...
Old 05-20-2015, 09:13 PM
What color are the wires? Hard to tell if they are striped in the pictures
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 05-20-2015, 09:40 PM
One is brown, one is red and black and the third is white and light green.
Old 05-20-2015, 09:44 PM
The brown and red/black should be for a second thermo-time switch but it looks like your oil breather cover just has a single switch. Not sure what the white/green is for.
Old 05-20-2015, 09:55 PM
ROW '78 911 Targa
timmy2's Avatar
Green/white is normally for oil level.
Old 05-20-2015, 10:22 PM
I was going to say oil level also but that wire is far away from the oil level sender so I'm guessing it's something else.
Old 05-20-2015, 10:27 PM
ROW '78 911 Targa
timmy2's Avatar
Just looked at the print before saying oil level.
Don't see any other green/white or white/green wires running to the engine area.
Porsche loved to run spares but they usually didn't terminate them with a 90.
And having just built a '67 harness I don't remember there being one.
I agree that wire shouldn't be in that location of it is green/white for the oil level.
Maybe it is a color fade and the op can get a look at the wire that isn't faded for the colors.
Green/ white is the color to the idiot light for oil pressure sender on later years as well.
Maybe a wire spliced in place of one that failed at some point?
Old 05-20-2015, 10:54 PM
As far as I can tell, every visible sender and hookup on the engine has it's associated wire. Unfortunately I don't remember if these wires dead ended when I pulled the engine. When I get home I can re-confirm the colors and take better pictures.
Old 05-21-2015, 11:43 AM
Kroon Wire Harnesses
Isn't the wire black-red instead of red-black ? Is this engine build in to a 914 (Vintage914racer) The harness looks a lot like a 914 and only the 914 has black-red in the engine wiring (used for the ignition coil) and also a green-white wire at that position.
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 05-21-2015, 12:23 PM
It is indeed in a factory 914-6. I ignorantly figured that since it has a 911 power plant that the wires would be the same. Apparently not.
Old 05-21-2015, 12:25 PM
ROW '78 911 Targa
timmy2's Avatar
That was a good catch Gerald, it would have been nice to know the engine is in a 914 body with a 914 harness.
Old 05-21-2015, 12:45 PM
914-6 harness
Here's how a original 914-6 looks like (you can recognize the wiring looks similiar)
Old 05-21-2015, 12:48 PM
We just manufactured a new 914-6 harness today and somehow it looked familiar Timmy2 !:-)
Old 05-21-2015, 12:51 PM
ROW '78 911 Targa
timmy2's Avatar
Lol, always helps when it is fresh in your mind.
Old 05-21-2015, 12:56 PM
Two of the wires in question are circled in red. I'll have to take closer look when I get home to remember where the 3rd comes out.
Old 05-21-2015, 02:35 PM
