I got the parts on eBay from a couple of different sellers. The parts are all well-made, sturdy not flimsy at all. It's hard to capture with my iPhone but the install looks OEM. Ebay Sellers: Andy14nq offroadarsenal Inexpensive, too! I installed a 15A inline fuse as well. Took 15 minutes tops to install. |
I've already got the spare gauge to work with. I talked to Harmut at Palo Alto, and he wasn't able to take on this project. I'll contact http://www.newvintageusa.com/bigmarkdesign.html For now I'll attach a multi-meter for my next road trip. I always like to bring one along in my tool kit anyway. |
Darn. They just got back to me to let me know they no longer work on our gauges
I have a donor fuel gauge
Any ecomonies of scale here if I piggy back on your project contributing to your cost recovery? |
Great addition for our cars CHT and VDC the other would be a Fuel Mixture gauge.
Lots of cool solutions here. Anyone find a cigg lighter option that is a bit more.... 80's looking?
Also wondering what the alternator idiot light reports? Total failure (ie belt snaps) under charge? Over charge? |
Thanks!
Standing by |
I ordered
http://forums.pelicanparts.com/uploa...1440813745.jpg I was planning to run it in mode 4 (below), maybe install it in the unused warning slot in my oil pressure gauge or on the dash where the OXYs light is. I still haven't received it so it could turn out to be junk. If not I'll do a write up and post it. Mentioning it now because it seems relevant. http://forums.pelicanparts.com/uploa...1440813581.png |
Here's some good information on the alternator light function. It's more than just a typical light bulb being turned on!
http://forums.pelicanparts.com/porsche-autocross-track-racing/723738-race-car-dash-alternator-light.html |
http://forums.pelicanparts.com/uploa...1442293872.jpg |
Can I order an electronic box from your guy?...or a kit with schematic??? Pre-assembled would be great.
Where can I get the gauge refaced? Looks like the prefect solution (other than narrowband, but I can live with that ;-) |
I too wish there was a way to use a wide-band sensor but the circuitry is much more complicated and we couldn't come up with a way to use the existing movements. For one of my other cars I'm putting together a wide-band gauge using the parts from a clock but it will be a full sweep gauge based on the innovate gauge (no volt meter). I'll post a picture of that in a couple days. |
Great advice Wayner, you motivated me to get some "insurance" as well.
My car has the dealer installed air conditioning unit installed. So I was able to buy a VDO bracket which fit perfectly in the space of the never used ash tray. I installed an OEM 55 mm VDO voltmeter and an OEM VDO 55mm outside temperature gauge Doesn't look too bad. I love knowing the status of my electrical system http://forums.pelicanparts.com/uploa...1446483663.jpg |
My battery gave up the ghost mid lap at a hpde. I lost all power and the hood was smoking a bit, but i was "lucky" and there was no leaking. I have since switched to agm batteries, and saved some weight in the process.
This WAS an AGM battery. AGM won't save you from a battery explosion if you are overcharging. Quote:
(I still haven't gotten around to following my own advice but I did ride with a multimeter on the passenger seat last outing). |
| All times are GMT -8. The time now is 12:56 AM. |
