super80's Avatar
Aligning FG front lid
Very slow progress on my 77 911s backdate project. Finally got around to fitting the TRE backdate FG front lid and need to tweak the fitment. Overall, it is sitting way too high on the car in comparison to the fenders when it should be more flush. I attached some photos. I searched the forum and read that the three bolts which hold each hinge to the body offer some alignment capabilities, but after loosening those bolts, it only seems to move the lid fore and aft, not up and down. I did not completely remove the three bolts on the hinge.
Also, I am reusing the existing rubber hood seal, perhaps this is adding to the problem? I did notice that the hood is quite light and does not compress the seal like a steel hood would.
Any tips?
Vic
What the FUCH ?
1977 Porsche 911S 3.2L Frankenstein
Old 05-26-2015, 02:04 PM
super80's Avatar
Vic
What the FUCH ?
Old 05-26-2015, 02:23 PM
Brew Master
cabmandone's Avatar
take your hood supports off and see what happens. If the hood is substantially lighter than a steel hood it will push the back of the hood up near the cowl panel like in your pics.
Just read your OP again. FG hood needs weaker hood supports as I have heard. I can't say firsthand but I sold a FG hood and was told it takes a shock that is "worn"
Old 05-26-2015, 02:55 PM
Elombard's Avatar
If worse comes to worse you may have to "oval" the 3 bolt holes on the hinges so they can be lowered. Maybe the pros will chime in...thats sort of permanent.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 05-26-2015, 03:01 PM
super80's Avatar
I removed the hood shocks completely, after reading in a few other threads that the FG hoods are too light and flexible to use shocks
Vic
What the FUCH ?
Old 05-26-2015, 03:29 PM
Brew Master
cabmandone's Avatar
Okay, make sure you don't have the latch mechanism on the hood, loosen the three bolts that hold the hinge to the frame and gently press down. The hinges should be able to roll forward which should lower the back of the hood where it meets with the cowl. I fought mine and ended up using a die grinder and making more adjustment in my hinge to get mine to line up. I've read that you can use worn shocks with a FG hood. If you want to test the theory, I think I have some old shocks around.
Old 05-26-2015, 03:45 PM
super80's Avatar
Thanks cabmando, will try a few things tomorrow evening after work.
Vic
What the FUCH ?
Old 05-26-2015, 05:56 PM
Tom '74 911's Avatar
I think cabmanado is correct, that the holes in the hinge, where they bolt to the inside of the trunk are a little enlarged or oblong. Hopefully you can get enough adjustment out of them to let the hood sit flush.
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 05-26-2015, 07:19 PM
super80's Avatar
Traded emails with David at TRE, and he suggested to raise the cowl a bit via the cowl brace in the trunk. Will try a few of these things in the next few days and post my results.
Thanks!
Vic
What the FUCH ?
Old 05-27-2015, 05:19 AM
Tags
alignment , hood , lid
