That is what I do, and I posted in the previous tips and tricks thread. |
"how in the world did you get the pin and clip back in after you removed them to replace the hydraulic rod with the neat mechanical ones we all bought? My hands and fingers can't get around the wiring down there on the drivers side to push the clip on.... thanks for reading."
Just use a short (I think 10mm) bolt. The threads and tension keep the sucker in place for at least ten years in my experience -- no problems yet. Used hemostat like pliers and dental floss to recover the bolt if it slips. I believe I got the idea from Pelican.
'89 cab |
I used a pillow to kneel down. My config has a nut/bolt, so it was pretty simple to access.
1986 Bosch Icon Wipers coupe. |
Straight shooter
I was replacing the fuel line/filter on my Stihl 036 last night. The replacement came from a shop in Florida and upon comparison, the new line required a larger hole in the fuel tank ; a 1/8" more in diameter to be exact. The tank is hard plastic and had to be drilled from the outside. I dipped the drill bit tip in grease to catch the chips as the cut proceeded. Also set an oil soaked rag inside the tank partially to catch any that snuck by the grease trap. Grease trick worked well enough that I couldn't find a single particle on the rag or in the tank.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
non-whiner
My best tip? My creeper make a great cot for a nap when I'm under the coolness of my Porsche.
"Too much is just enough." |
I'll add something so basic that I overlooked it for many years. 4 lb hammer. I wanted to tap out the brake pad pins, and finally got to use my heavy hammer. There was limited swing clearance, so the extra mass made it perfect compared to using a nail hammer. When you need a heavy hammer with limited swing arc to build momentum, the BFH has no substitute. I barely moved the hammer and it carried a lot of force.
That is not much fun!! I love doing my own work......and becoming an expert in the things I choose.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Member 911 Anonymous
Starter Removal and Install. 20 minutes.
Chock the front wheels, put in neutral, raise the rear on jack stands, from the bottom on a creeper reach in from the driver side over the gear box to access the mounting 10MM barrel nut ( 3.2 ). 33ft lbs If you have Hi-Torque Starter, the same process to get to the Positive 12MM connector. 7.5 ft lbs.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
My garage can sometimes be the most peaceful place in the house. Sometimes. Sometimes it's filled with oil and blood and swearing.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Bit of rubber glove or shop rag jammed in a socket with a bolt or nut is a great way to secure the bolt/nut during install.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
^^^ +1, I take cat naps under her too
There were quite a few nights when I was rebuilding the engine that involved a few hours of low end manual labor...scraping, cleaning, wiping and drinkin'. Those often ended with me slumped over in the chair...cause of the drinkin' and all...
The biggest tip I can offer is to check out your local pawn shop. I've scored so many Snap On bits that I've lost count. Dozens of extensions, ratchets, socket sets, and specialty tools that my box is overflowing with Snap On goodness. I have drawers and drawers filled with everything from SO compression testers, strut compressors, speed wrenches, boroscope, etc.... All at 60-75% off truck price. Just picked up a $99 pyrometer for $20. A half dozen of my socket sets were $60 each, not the $300 the truck wants.....some still in the original shrink wrap packaging and magnetic holders. Does a shade tree do it yourselfer need Snap On? No? Want to bet? ![]()
gduke2010
Put a 1/4" hose on the end of a spark plug to start the threads then torc the plug with a socket
French Import
Reason #1: make sure nothing went wrong and I am pinned under the car. Reason #2: wake me up if I fell asleep on that comfy moving blanket I spread under the car...
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
French Import
Straight shooter
My garage is detached and WiFi for the house doesn't quite reach. The kitchen is the midway point between garage and router. I had a spare router that I re-flashed with DD-WRT firmware and set as a repeater in the kitchen. Now there's nearly full strength WiFi in the garage. Considering the spare router had no appreciable resale value, this was a useful and virtually free trick.
J Mac Current 0 Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified |
Stomski racing - specialized engine assembly tools.
That is one clever hombre.... |
