RallyJon's Avatar
Question Early transmission mounts: Solution?
Every discussion I read on this topic has the same non-answer.
What is the upgrade path to installing "clubsport" or solid transmission mounts on an early car with the pressed-in mounts.
1) Can the stock mounts be pressed out of the crossmember and replaced? If so, who makes/sells higher durometer or solid replacements?
2) Can a later crossmember with replaceable mounts be swapped in? Does it bolt right up or are there issues?
3) Does some racing shop make a complete aftermarket replacement?
Seems to me the world must be running out of supply for the "find a used replacement in good condition" solution someday...
Old 11-08-2002, 09:05 AM
