Post Pedal Cluster Roll Pin Properly Installed....Finally
After ruining 3 pins by trying to press them in alone, I ended up using the old pin (which I presses out of the pedal cluster without damaging it) as a guild for the new one and it worked great. Since the old pin went in so easily I pressed it in slightly below the surface of the shaft and started the new one in directly behind it and the new one is in and the old one is out. This wont always work for every situation but I think its a good thing to keep in mind when doing this job. I certainly wont forget it next time. If you can get the old pin out without ruining it save it and use it as a guild for future roll pin installations....TargaEuro
[This message has been edited by TargaEuro (edited 09-29-2001).]
Old 09-29-2001, 08:36 PM
