Shifting support fork
So I'm having a few problems shifting in the 1st - 2nd gears. I've changed, the bushings (shifter, tunnel, coupling) and oil (swepco) but still no improvements... So I opened up the cover underneath the tranny, where the support fork is located. It's not loose or broken, although there seems to be a bit of wear on one side (see picture) but I doubt this is what's causing me trouble. Any ideas? Time to change the synchros?
Looks fine to me.
Probably worn synchros if you have trouble going into 2nd from 1st.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
As long as the swepco is out, put some kendall 80/90 in there so it will shift as well as possible.
These forks do bend and open up slightly which is easy to measure.
Any wear or bending will be seen as increased stick movement and reduction in the 'definition' of the gate, it doesn't really affect the shift as such. I would agree with chucking the Swepco out - we use a Motul Technosynthese with good results as I can't find Kendall in the UK. |
Racer
Of course it is Swepco's fault.....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Possibly
- I have never much liked the shift quality of a 915 with Swepco.
gearhead
At what rpm do you make your 1-2 shift?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Looks like classic gear contact due to output shaft walking. This happens when there is significant wear on the 4 point bearing and/or the bearing retainer.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Almost Banned Once
Here's mine... Note the sealant and I had broken studs when I took it out. Please double check yours.
- Peter |
So far Swepco 0 - Kendall 4 !!
As for my studs, I haven't taken them apart since the fork seems well secured to the cover. |
Armed Bastard
Damion '77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition |
Measure inside the fork at the bottom and see if the top is the same.
Armed Bastard
So it should be fairly consistent from top to bottom?
