Shifting support fork
So I'm having a few problems shifting in the 1st - 2nd gears. I've changed, the bushings (shifter, tunnel, coupling) and oil (swepco) but still no improvements... So I opened up the cover underneath the tranny, where the support fork is located. It's not loose or broken, although there seems to be a bit of wear on one side (see picture) but I doubt this is what's causing me trouble. Any ideas? Time to change the synchros?
Old 06-03-2015, 06:50 PM
Oh Haha's Avatar
Looks fine to me.
Probably worn synchros if you have trouble going into 2nd from 1st.
Pacific Blue
Wayne
Old 06-03-2015, 06:53 PM
As long as the swepco is out, put some kendall 80/90 in there so it will shift as well as possible.
206 637 4071
Old 06-03-2015, 09:46 PM
These forks do bend and open up slightly which is easy to measure.
Any wear or bending will be seen as increased stick movement and reduction in the 'definition' of the gate, it doesn't really affect the shift as such.
I would agree with chucking the Swepco out - we use a Motul Technosynthese with good results as I can't find Kendall in the UK.
Old 06-04-2015, 12:32 AM
Racer
winders's Avatar
Of course it is Swepco's fault.....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 06-04-2015, 01:35 AM
Possibly - I have never much liked the shift quality of a 915 with Swepco.
Old 06-04-2015, 07:30 AM
gearhead
At what rpm do you make your 1-2 shift?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-04-2015, 07:38 AM
Josh D's Avatar
Looks like classic gear contact due to output shaft walking. This happens when there is significant wear on the 4 point bearing and/or the bearing retainer.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 06-04-2015, 08:33 AM
Almost Banned Once
sc_rufctr's Avatar
It's interesting that your shift fork plate looks a lot like mine.
Here's mine... Note the sealant and I had broken studs when I took it out.
Please double check yours.
- Peter
Old 06-04-2015, 04:25 PM
Upshift usually is around 4K RPM, downshift is about 1K I guess...
Old 06-04-2015, 05:51 PM
So far Swepco 0 - Kendall 4 !!
As for my studs, I haven't taken them apart since the fork seems well secured to the cover.
Old 06-04-2015, 05:56 PM
Armed Bastard
djb25's Avatar
Where would I find the correct dimensions?
Damion
'77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition
Old 06-05-2015, 05:48 AM
Measure inside the fork at the bottom and see if the top is the same.
206 637 4071
Old 06-05-2015, 06:20 AM
Armed Bastard
djb25's Avatar
Well, that makes me look like a damn idiot, doesn't it?
So it should be fairly consistent from top to bottom?
Damion
Old 06-05-2015, 08:55 AM
