Brew Master
cabmandone's Avatar
Had my injectors cleaned by MR Injector
I recently sent my injectors in for cleaning. I did some reading and found two names that came up in a lot of threads. I chose MR Injector after reading a lot of comments. I haven't installed the injectors yet but I have to say they look very nice (new). One of the biggest complaints I read about others was that no paint was applied to the outside to protect them. Mine were nicely painted and individually wrapped or bagged in those heat seal bags and then all put in a larger heat seal bag. And possibly best of all they threw in 2 jolly ranchers, I mean.. who doesn't like those? I got a nice sheet showing before and after cleaning flow. None of mine were bad. The worst one was 61 and now all are 65. I'll try to post some after pics since I didn't take any before pics.
Old 06-12-2015, 07:04 PM
bugstrider's Avatar
Interested to see the results
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 06-12-2015, 09:49 PM
Good info, BTW, are there any telltale signs that injectors need to be treated?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 06-13-2015, 07:17 AM
There is no signs that the cleaning is needed but for just over $100 you have that piece of mind..and you get the Jolly Ranchers..
Bruce
Old 06-13-2015, 09:23 AM
Brew Master
cabmandone's Avatar
The main reason I had mine done is I have the engine torn down replacing head studs. I figured while I had it down I might as well get them cleaned.
Here are some pics of how they were packaged and how nice they looked after.
Old 06-13-2015, 06:32 PM
Brew Master
cabmandone's Avatar
I forgot to add the sheet he sent on flow before and after.
Old 06-13-2015, 06:37 PM
Racer
winders's Avatar
I just had the injectors in my race car cleaned. I chose R.C. Engineering because a friend had used them with good results and a local racing shop with a great reputation with fuel injected cars uses them for all their injector cleaning. Plus, their turn around time was fast and I was in a hurry.
I don't have the injectors back in hand. But I do have the test report.
Code:
                BEFORE                                 AFTER
Inj.#       CC/Min         Pattern     Inj.#       CC/Min         Pattern
1           332.0          Fair        1           360.0          Excellent
2           347.0          Fair        2           367.0          Excellent
3           341.0          Fair        3           359.0          Excellent
4           341.0          Fair        4           362.0          Excellent
5           337.0          Fair        5           372.0          Excellent
6           349.0          Fair        6           360.0          Excellent
I race the car next weekend. I'll report back on how the injectors work.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 06-13-2015, 06:59 PM
Brew Master
cabmandone's Avatar
Code:
                BEFORE                                 AFTER
I forgot to mention turn around time. It took about 9 days total from ship to receive. The test will come when my engine is back in but since mine were pretty clean to begin with there probably isn't going to be much noticeable difference.
Old 06-13-2015, 07:01 PM
Racer
winders's Avatar
When I say fast, R.C. Engineering quotes 24 hours at their shop. Total time depends on how you ship and how you want them to ship back.
Scott Winders
PCA GT3 #3
Old 06-13-2015, 07:11 PM
Brew Master
cabmandone's Avatar
Most of my time was spent in shipping. I went the USPS priority route. The injectors left my brother's place in VA on Tuesday 6/2 and by 6/5 I had an email stating my injectors had been serviced. Keep in mind, my time above included a weekend. I have no complaint with the turnaround time.
I'm curious, how much did it cost to get them done? My bill was $130 with the ship to costing $17 due to me placing a higher insurance value on the injectors in the event they got lost in transit. I figure if USPS screwed up, I'd get a new set of injectors rather than a rebuilt set.
Old 06-13-2015, 07:30 PM
Racer
winders's Avatar
$24 per injector if the standard top/rail feed style injectors like yours or mine. Shipping rates depend on how fast you want the injectors back.
Scott Winders
PCA GT3 #3
Old 06-13-2015, 08:10 PM
Ferrino's Avatar
Great info. How long do they suggest between having them cleaned and running them on the engine? IIRC, they can tend to seize if you leave them too long?
Old 06-13-2015, 08:34 PM
Or just use Techron once in a while. If your car runs just fine, then the injectors do not need cleaning.
Old 06-13-2015, 09:57 PM
Brew Master
cabmandone's Avatar
I've read a lot of threads on the topic of stuck injectors. My engine sat for over 5 years while the PO tried to build his car. I must have gotten lucky. As for how often to clean I say the best thing to do is use a little preventative maintenance and run some injector cleaner occasionally and make sure you put a fuel stabilizer in if you part it for the winter.
Old 06-14-2015, 04:27 AM
Brew Master
cabmandone's Avatar
Okay, I paid $17 per injector plus shipping both ways. He used USPS priority on the send back. I'll bet your guy doesn't throw two Jolly Ranchers in the box
Old 06-14-2015, 04:30 AM
Very important step when having the heads rebuilt
If you combine new,tight valve guides with a lean injector you have a disaster waiting to happen
There's many places to get it done. I use Marren because they're a mile from my shop
Cheap insurance especially when dealing with 30 year old injectors
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 06-14-2015, 09:38 AM
Racer
winders's Avatar
I didn't pick RC Engineering based on cost. I asked a local top notch race shop whose cars are almost all fuel injected what company he used to clean injectors. Then I did some research on the company. After that, it was an easy choice. The turnaround time was a bonus I was willing to pay for but did not have to.
Scott Winders
PCA GT3 #3
Old 06-14-2015, 10:38 AM
Racer
winders's Avatar
Dan J, I agree. There is a lot more to clean and proper functioning injectors than running Techron through them once in a while!
Scott Winders
PCA GT3 #3
Old 06-14-2015, 10:40 AM
bugstrider's Avatar
Does this apply to newer injectors only or would an older CIS system benefit as well?
1978 911SC Targa
Old 06-21-2015, 07:11 PM
Some of the very best on this site say Techron does the job. If your car runs great, why would you send them out ? If your car runs terrible and stumbles, send them out.
Old 06-21-2015, 07:46 PM
