NathanR's Avatar
Send a message via Yahoo to NathanR
Originally Posted by DaveMcKenz View Post
BTW, I really like your system, and IF my Wwested design does not perform well enough, yours will be my next step. I already have most of the parts and will just need one hose made.
Thanks for sharing,
Dave
Thanks Dave M.
Let me know if I can help with the hose. I anticipate ordering at least 1 more shipment of hose bits, and I have some extra #8 hose (good for connecting the deck lid condenser to an additional wheel well condenser.)
87 Carrera Coupe
Black on Black, H4 Headlights, Nurburgring Sticker
Old 06-17-2015, 06:48 PM
NathanR's Avatar
Originally Posted by Wavey View Post
BTW, I had to replace my temp control, and feeding that capillary tube through the console and firewall and into the evap box was a M@+#&r#@%er. You get my drift. Lots of finesse required. Not sure if you're getting that.
I hope not, it worked before the system ran out of juice a couple years ago. I'll try not to break it when I remove the evaporator.
I'm assuming I can open the box, disconnect the hoses and wires and whatever nuts and bolts are required. That's on my agenda for the coming weekend.
87 Carrera Coupe
Old 06-17-2015, 06:55 PM
NathanR's Avatar
Well, good news, the capillary tube seemed perfectly fine and came out of the Evap box without drama. Today I got the evaporator out of the car.
87 Carrera Coupe
Old 07-03-2015, 07:57 PM
NathanR's Avatar
Not nearly as bad as Karl's (discseven)
87 Carrera Coupe
Old 07-03-2015, 07:58 PM
NathanR's Avatar
I've not had much time to work on my project over the past few weeks. Plus, ironically, it's been so. Damn. Hot. I've not wanted to be in the garage.
What work I've completed has been pulling and replacing hoses. A bit tedious. I have one left to do, the Evap to compressor hose, and I'm waiting for more hose to arrive in the mail
87 Carrera Coupe
Old 07-03-2015, 08:03 PM
NathanR's Avatar
Also, today I confirmed one needs a 7/16th inch hi side service port adapter.
This one didn't fit
I did order the right one, I just didn't get the right one.
Also, I had to take the port plate off the compressor to allow the pressure switch to clear the compressor body. If I had it to do over I would get a hose fitting with a switch port built it instead of in the adapter.
87 Carrera Coupe
Old 07-03-2015, 08:11 PM
NathanR's Avatar
In order to get the port plate off, I had to buy a 6mm Allen wrench-headed socket. Took a LOT of torque. Must have been heat cycling.
87 Carrera Coupe
Old 07-03-2015, 08:13 PM
NathanR's Avatar
Another tip to would be hose-fabricators: if you test-fit your hose before crimping the fitting but you don't clamp down every little bend in the hose, your hose will be 3-4" too long. Don't ask me how I know...
87 Carrera Coupe
Old 07-03-2015, 08:16 PM
Banned
Hmmmm, reads like the voice of experience right thar!
Old 07-03-2015, 08:23 PM
NathanR's Avatar
This weekend I'm hoping to fit my new Kuehl evaporator blower motor and install my new rennaire Evap coil, and put the whole box back in the car. Time permitting, I may actually wire up the new fan on the 993 condenser.
87 Carrera Coupe
Old 07-03-2015, 08:24 PM
Glad to read Silbur's comments since I'd been thinking of a way to fab up a shield from some leftover radiant barrier material. Also, to clarify, this condenser is for the rear wheel well...right? I saw some comments about the washer bottle being removed and got confused. I just got the same crimper and did a test run with the hose from the compressor to the deck lid condenser and initially the ferrul seemed to "squeeze out" at the joint between the two dies then closed down around them. I think some sort of lube would have allowed the dies to slide down around the ferrul better.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 07-04-2015, 06:07 AM
NathanR's Avatar
Buck,
Yes, behind left rear wheel.
87 Carrera Coupe
Old 07-04-2015, 07:08 AM
wwest's Avatar
"Kuehl evaporator blower motor.."
Is that still the one that requires back-dating the blower wheel to the pre-84 model?
If so that appears to me to have a strange aspect in that the '84 and later blower wheel seems to be a significantly changed, improved, design.
But then maybe the design improvement was only to reduce the noise factor and did not result in higher volume airflow.
Anyone actually measure before and after airflow volume..??
Old 07-04-2015, 09:41 AM
wwest's Avatar
86-88+ A/C evaporator blower motor/wheel.
Did you consider this.........?
Motor/Blower upgrade for 86-88
Evaporator Blower Motor Upgrade, 911 86-89
Old 07-04-2015, 10:23 AM
wwest's Avatar
Hi Nathan,
I used lots of Nylog on my system. I think of it as a thread lubricant, so the surfaces can seat properly. I think it is made from a/c refrigerant oil, and becomes quite viscous. Within reason I don't think it has much of a downside, such as clogging your system. OTOH I think Griff assembles his stuff dry, but he's a pro with lots of experience.
Thanks for sharing,
Dave
Speaking of which.... what is current status..report?
Old 07-04-2015, 10:32 AM
Out of town. Will update soon.
Happy Fourth,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 07-04-2015, 10:52 AM
kuehl's Avatar
Porsche changed the evaporator box and blower assembly in 1986. If LHD clients want to use our Hurricane blower motor on 86+ cars, all they need is a box top, plastic motor platform and metal blower wheel from any Behr unit in a 911,912, or 930, years 1970-1985. For RHD's, its a drop in, no other parts needed.
Old 07-04-2015, 12:04 PM
wwest's Avatar
But does your "Hurricane" blower motor with the "back-dated" blower wheel really provide more air volume movement vs the 86-88 factory version.
Why not supply a Hurricane blower motor that drives the improved(***) design of the 86-88 blower wheel.
Porsche engineering didn't design the new blower wheel "just because".
Old 07-04-2015, 03:24 PM
NathanR's Avatar
Experts, question: where should I tuck the TVX pigtail?
87 Carrera Coupe
Old 07-04-2015, 04:31 PM
NathanR's Avatar
Was thinking the little cavity that is stuffed with foam inside the lower right corner. Lower right is close enough to reach.
87 Carrera Coupe
Old 07-04-2015, 04:33 PM
