Science is NOT optional
rbogh901's Avatar
PMO/Weber filter element options
What are the options for air filters these days? Does K and N honor their million mile warranty? The rubber edge on mine is cracking and I'm wondering what the alternatives are. Thx.
PCA member since 1993
Old 10-08-2009, 01:31 PM
rbogh901's Avatar
And meanwhile, being basically a cotton element, what are the options for K and N cleaning solutions? Searches for K and N generally degenerate into discussions as to whether or not they are better than paper elements. I've used K and N cleaning, solution, cleaner, etc...
Old 10-08-2009, 01:48 PM
While on this filter subject can anyone provide the K&N part numbers to suit the PMO / Webers
Have difficulty in sizing from the K&N catalogue
Paul
Old 10-08-2009, 10:49 PM
rbogh901's Avatar
Does anyone clean their k an n's?
Old 10-09-2009, 11:01 AM
rfuerst911sc's Avatar
Yes I do I use K&N filter cleaner.
Old 10-09-2009, 03:01 PM
Me too.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-09-2009, 03:52 PM
brads911sc's Avatar
sorry to revive this thread. I have searched...
I have new PMO ITB's with rain shields and K&N filters. Does anyone make a paper filter element that is the same size and shape as the K&N?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 03-25-2010, 04:28 PM
That seems to be the million dollar question . I have asked on several forums and no one seems to know of a " regular " filter in the correct size.
Old 03-25-2010, 05:18 PM
As far as I know, the K&N is the only one. If you maintain it carefully and oil it according to instructions, it works fine. I'm simply not losing any sleep over what micron size of particle is making it through. Life's too short.
Between ZDDP compulsives, filter wackos, Cool Collar hysterics--yeah, I've got one of those too, took it off my last airplane when I sold it--Magnacor fanatics, Swepco sissies and oh-god-do-I-have-the-wrong-sparkplugs worrywarts, we probably should just park our little dears and have them cryogenically preserved before we do terminal damage, like putting miles on them.
Drive the frikkin' thing.
Stephan Wilkinson
Old 03-25-2010, 05:40 PM
brads911sc's Avatar
Not at all obsessed with any of the things you mention... dont own a cool collar... run standard copper bosch plugs... however, I do prefer paper air filters... and if they made one Id buy it... just prefer to buy replacements and toss in the trash when dirty...
Old 03-25-2010, 06:13 PM
No paper element options for the PMO's: K&N's only.
I am working on some ITG options but those are inappropriate for most street cars.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-25-2010, 06:42 PM
Senior Advisor
James Brown's Avatar
LOL!!! Thanks Steve!!!!
08 Cayenne Turbo
Old 03-25-2010, 07:52 PM
I suspect K&N spec'd their housing to their custom-sized filter for a reason. I performed a serious search a few years ago, and K&Ns designed these housings to fit only their filter. An alternate filter housing that uses off-the-shelf paper filters would be a popular item.
I believe these foam filters are available from GCA Industries (True Flow) in Scottsdale AZ.
True Flow Yellow Porsche Filter 1965-1973
Part Number 85212
Sherwood
Old 03-26-2010, 12:11 PM
JFG JFG is offline
Anyone use itg?
Old 03-26-2010, 02:57 PM
Originally Posted by JFG View Post
Anyone use itg?
Uhhh, yes.
This was a previous setup with Filtron stamped Al. housings and modified Amsoil foam filters:
Sherwood
Old 03-26-2010, 10:25 PM
rbogh901's Avatar
Paul
Late to the party but here is something for those who might follow...
List Price: $61.68
E-3671 - K&N Replacement Filters, Custom Air Filter direct from K&N
Old 04-28-2013, 06:38 PM
Senior Advisor
there is s thread on here where someone took a round fram filter and made it into a oval filter, best part they were only about 5 bucks each
08 Cayenne Turbo
Old 04-28-2013, 08:10 PM
Ruby911
ruby911's Avatar
Anyone use itg?
Yep, but I wish I didn't ( I already had them so I used them). I think they are fine for race applications but worry about a street appilcation as I fear they will let rain water in. I spent last weeken at Road Atlanta for The Mitty and each night I had to put a rain coat over the motor to keep the deluge out. I would prefer, and will eventually get, some rain hats with K&Ns.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 04-29-2013, 04:21 AM
mskala's Avatar
Info is about half-way down the page here:
K&N Air Filters for Webers - What do I have?
Note that the height is about 1/4" taller.
Mark S.
'70 914-6
Old 04-29-2013, 08:58 AM
Pete000's Avatar
One thing I noticed on the new K & N set up vs the old K & N set up is the mounting posts are not in the same location making the lids not interchangeable and the posts are pop riveted on compared to the more robust bolted on posts in the older design. On mine one of the posts just spun around making it impossible to tighten the nut.
The old NLA version is much better. IMHO.
Work to Live, don't live to work...
Old 04-29-2013, 12:06 PM
