virob's Avatar
deep freezing struts
I have new front Bilstein struts and need to install new spacers on the spindles. I was going to try heating the spacers to get them on easier. I also have access to a -80 C (-112F) freezer and my initial thought was to pop the strut in there first and then that spacer should just drop on no problem. Any reason not to cool strut/shocks that low?
84 911 Chiffon white
Old 06-26-2015, 08:52 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Do the struts have the shock inserts in them? That'd be my only fear- unknown if the oil in the shocks would be affected by the super cold temperature.
You have the right idea about installing the spindle collars/spacers. I have removed these a few times and a two jaw puller, along with some short bursts of heat from a propane torch, allowed them to draw off nicely. For re-installation I heated them up with a heat gun (an outdoor grill or the typical kitchen oven would work good too) and they slipped right on.
Don't forget to put an o-ring behind each collar. The o-ring seals the filleted transition on the spindle and prevents wheel bearing grease from migrating out of there.
Kevin L
'86 Carrera "Larry"
Old 06-26-2015, 09:25 AM
No reason I suppose, but heating the spacer is pretty easy.
Barbeque's are a wonderful thing...as are heat guns. Just did two sets of struts a short time ago, heat gun did the job with a little tapping....
Dennis
Old 06-26-2015, 10:42 AM
I did mine 3-4 years ago and used the oven in the kitchen to heat to 190 degrees c for twenty minutes. They slipped on most of the way and then I used a hammer and length of copper pipe the same diameter to seat it flat. Really easy
Old 06-26-2015, 12:18 PM
virob's Avatar
Yes, and that is also what I was wondering. Maybe better to not risk it, or just us a standard freezer.
Sounds like just heating the collar works for most. That s easy enough to do.
Thanks all.
Old 06-26-2015, 07:12 PM
