Are these 02 Sensor wires?
I pulled these random wires out. I think my cat conv. has no 02, so these were just left dangling?
It's a 79 SC. There is a small 'pop' off throttle (under load). It revs up perfectly quick to 6000 with no load, but under load it seems to be under powered at lower RPM's. Also idle is closer to 1200 rpm. |
Brew Master
Looks like the license plate light wires or the tail light harness with wiring for oil level in the harness.
79 does not use ox sensor system. Bruce Last edited by Flat6pac; 06-27-2015 at 02:29 AM.. |
El Duderino
Looks like license plate light wires to me.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
euro fog light
ROW '78 911 Targa
License or oil level on passenger side, license or euro fog lamp on drivers side.
Ahh yes! I see my license plate wires are not hooked up as I don't have lic. plate lights! These are just dangling but thank you fellas!
You guys are great ![]() (I tend to worry and assume the worst, this is great news). And I did notice the 911 wakes up past 3000 RPM's. |
Brew Master
The plan is to change plugs, plug wires, do the valves then I'll set the idle. Not sure if this is the correct order. (It's the order for ACVW's).
(The car sat for long periods without being driven). And it seems to be coming alive the more it's driven! ![]() |
Thread Tools | |
Rate This Thread | |
